Skyynet Posted November 19, 2021 Report Share Posted November 19, 2021 Can the 1000g scan continuously without stopping? Quote Link to comment Share on other sites More sharing options...
0 WROA675 Posted November 19, 2021 Report Share Posted November 19, 2021 42 minutes ago, Skyynet said: Can the 1000g scan continuously without stopping? Not sure, don't have one, however I assume most radio's has similar functions...here's from the KG935G manual: Function: Scan mode settings Options: TO/CO/SE Default: SE TO: When a signal is detected, scanning stops. Scan will pause to wait for further activity and will then resume if no operation is carried out within 5 seconds. Pressing PTT will transmit on the currently selected channel. CO: When a signal is detected, scanning stops and resumes immediately after the signal is lost. Pressing PTT will transmit on the currently selected channel. SE: When a signal is detected, scanning stops. Pressing PTT will transmit on the channel where the signal was detected. Skyynet 1 Quote Link to comment Share on other sites More sharing options...
0 mbrun Posted November 19, 2021 Report Share Posted November 19, 2021 Can the 1000g scan continuously without stopping?Yes it can. @Papatree has identified the three scan choices on the 935. These choices, and there behavior, have been the same on every Wouxun radio I have ever used. One choice ends scanning the moment it detects a signal, one choice pauses for 5 seconds when it detects a signal and then automatically resumes, one choice pauses to permit you to hear a conversion and then continues after a period of inactivity on the channel.MichaelWRHS965KE8PLM WROA675 and Skyynet 2 Quote Link to comment Share on other sites More sharing options...
0 WyoJoe Posted November 20, 2021 Report Share Posted November 20, 2021 20 hours ago, Skyynet said: Can the 1000g scan continuously without stopping? Why would you want it to? I know when I'm scanning, I want the radio to stop scanning when it detects a signal. Skyynet 1 Quote Link to comment Share on other sites More sharing options...
0 mbrun Posted November 21, 2021 Report Share Posted November 21, 2021 Why would you want it to? I know when I'm scanning, I want the radio to stop scanning when it detects a signal.That is my preferred mode of operation too, there are reasons one might want other modes. One such reason for continuous scan is when you are most interested in hearing communications from a specific person or persons that might be operating on different frequencies. If the scanner stops and holds on a single frequency for the duration of a long QSO, you run the risk of missing comms from those other parties while the QSO takes place. While this might be best handled by a dedicated scanner, it is a capability that would benefit some.RegardsMichaelWRHS965KE8PLM Skyynet 1 Quote Link to comment Share on other sites More sharing options...
0 MMallang Posted November 26, 2021 Report Share Posted November 26, 2021 On 11/19/2021 at 10:23 AM, Skyynet said: Can the 1000g scan continuously without stopping? Hello Everyone. I just got my GMRS license and have setup a base station using a KG-1000G. I am still in the learning process. The scan feature annoyed me at first, then I realized I was wanting a seek feature. After reading the manual... The scan mode has 3 options. Menu [10]: SC-REV Function: Scan mode settings Options: TO/CO/SE Default: SE TO: When a signal is detected, scanning stops. Scanning will resume if no operation is carried out within 5 seconds. CO: When a signal is detected, scanning stops and resumes 3 seconds after the signal is lost. SE: When a signal is detected, scanning stops. Press the PTT key or function key to store it. Menu [11]: TOT SE works best for me. Hope this helps. Skyynet 1 Quote Link to comment Share on other sites More sharing options...
Skyynet
5 answers to this question
