Guest Billy Posted April 18, 2022 Report Posted April 18, 2022 I recently installed my new MXT500 and put several channels in the scan list by holding the scan button for 2 seconds, however when you Tap scan. It only makes 4 quick beeps and nothing happens. I can not get it to scan channels. Any suggestions? Thanks in advance Quote
wayoverthere Posted April 18, 2022 Report Posted April 18, 2022 The one possible thing I see in the manual is that it comes configured to scan all the channels out of the box; are you sure you added the channels rather than. Removing them from the scan? The manual seems to indicate a period after the CH icon indicates a channel active in the scan list. Quote
WRPT357 Posted April 18, 2022 Report Posted April 18, 2022 8 hours ago, Guest Billy said: I recently installed my new MXT500 and put several channels in the scan list by holding the scan button for 2 seconds, however when you Tap scan. It only makes 4 quick beeps and nothing happens. I can not get it to scan channels. Any suggestions? Thanks in advance I had the same problem with mine, contacted Midland for advice, but was on the weekend. Before they contacted my back, I got impatient, and just did a Restore. Scan function began working, problem solved Quote
