Ringo Posted April 29, 2022 Report Posted April 29, 2022 I am new to GMRS and radios in general. I reached out for approval to a local repeater and was given the details, but I am a bit unsure how to translate that to CHIRP. Here is what I was given: TX 467.625 DPL XXX / RX 462.625 DPL XXX. In CHIRP I am programming a DIY channel (frequency 467.625000 with a +5 offset). For the DLP, I am trying to set the DTCS code and the DTCS Rx code, but it only lets me set one. Also, the DTCS poll gets set to NN, is that what I want? Sorry for a newbie question. Quote
wayoverthere Posted April 29, 2022 Report Posted April 29, 2022 https://chirp.danplanet.com/projects/chirp/wiki/MemoryEditorColumns This page may help clarify, when Tone Mode is DCS (the correct entry for a repeater that uses DPL), the radio will use the same DCS tone for both tx and rx, based on the DCS Tone column. On the DCS Pol column, that refers to Polarity, either Normal or Inverted; if not specified in the listing, it's usually assumed to be normal polarity. Quote
Ringo Posted April 29, 2022 Author Report Posted April 29, 2022 In my case the DLP is different, so I should use DTCS>DTCS cross mode? Quote
wayoverthere Posted April 29, 2022 Report Posted April 29, 2022 1 hour ago, Ringo said: In my case the DLP is different, so I should use DTCS>DTCS cross mode? Yes, that should let you set the DCS rx code separate from the DCS code used for tx. Ringo 1 Quote
Ringo Posted April 29, 2022 Author Report Posted April 29, 2022 Great, thank you! wayoverthere 1 Quote
Dave453 Posted April 29, 2022 Report Posted April 29, 2022 (edited) What kind of radio are you programming? Were you able to first download a copy of everything currently in the radio and save it to your system? I would recommend you then save another copy with the word WORK in it so you know it isn't the original that you might need should you accidentally brick your radio. The rest of this is my "opinion" and may be contradictory to what you hear/read but if you give it a try it probably will get you on that repeater. <Wink> After editing you should be able to first save your "WORK" then upload it to the Radio... In your case you probably will wind up with a line that reads something like this at one of your locations: Loc # = Self explanatory Frequency = 462.625000 Name = (Something like) RPT625 Tone Mode = Tone Tone = the value of the PL code he/she gave you to transmit into the repeater (if you click on the space a nice drop down menu will pop up) Duplex = + Offset = 5.000000 Mode = FM (then again it might be WFM depending on what specific radio you are programming - don't use NFM) Power = High (generally - but up to you). All the rest should probably be blank just to get it working.... OK, there is my two cents, for what its worth. Hope this helps get you going. I sure wish you luck and want to say Welcome to GMRS! Dave453 WRPZ453 OBTW, in my experience, there is no reason to set up my radio with a receive tone, you will hear what is being said anyway and its just another step that can get fouled up. If you had two repeaters fairly close by, and you only want to hear what is said on one of them - I guess you could use the receiver "trick", but to be honest - seeing that situation generally is pretty rare. JMHO. A final thought - some of the Chinese radios that have been getting FCC approval for GMRS have a problem if you try to edit more lines for GMRS use than the 8 they have pre-programmed. I have a BTECH GMRS 50X1 that is like that. If that is the case you will be forced to edit the line that already contains the repeater frequency you want to use and just set the Tone properly to get in. Again, good luck with this! Edited April 29, 2022 by Dave453 Correct text Ringo and Rooftop 2 Quote
Screech Posted April 29, 2022 Report Posted April 29, 2022 @Ringo I see @Dave453 already corrected one part, but didn't really point it out. You indicated you set the freq to 467.625, it should be 462.625. When you are setting up the repeater channels in Chirp you setup the radio's receiving freq (the freq the repeater transmits) and then your offset indicates where you transmit relative to that receiving freq. Also, you noted DPL, were those frequencies or 3 digit codes? If there were 3 digit codes, you put that in the DTCS Code column, not ToneSql, and set the Tone Mode to DTCS. Ringo 1 Quote
Ringo Posted April 30, 2022 Author Report Posted April 30, 2022 Thank you all, this is great help! Quote
