AM radio on Wouxun KG-1000G
WRPN639
3 answers to this question
You can check if AM is supported on a channel/Freq by bringing up the menu and enter 0-5-4 on the keypad, if you see AM-SW option that channel/freq supports it. To quickly test you can press menu again and toggle it on/off as normal and press menu again to confirm selection. As @FrostyFruits points out, when you set this on the radio it will reset when you change channels, but when set in the programming software it is persistent to what was set there (now if you disable it on the radio, it will be set again when you leave the channel and return).
As for the Aut.AM 053 menu item, I don't know my radio never auto switched to AM, maybe the signals were not strong enough in my area to auto switch to AM. The local airports use AM, setting it in the programming software was the best option for me.
