I recently picked up a new Wouxun KG-935G and have noticed some odd scanning behavior that I was hoping to get more info on.
When I scan channels, it stops every couple of channels as to indicate there is traffic on that channel. It even shows a full blue bar across the screen as if someone was transmitting and I was receiving a full signal from them. However, every time it does this, there is no audio.
In addition to that, when I hit exit to stop the scan, the signal immediately goes away. When I scan I consistently see this behavior, but if I was to manually scan through the channels I will not see this behavior.
Also, when using another radio and key up on those same channels, I receive audio just fine on the KG-935G. It's also worth noting that I do not have any CTS or DCS tones/codes set and this pertains to just plain old GRMS channels.
Am I missing something here? Is there a setting in the menu that may be causing this?
Huetarded
Hello!
TIA - Jason
11 answers to this question
