SWR/Watts reading from RT-97
If I connected everything correctly, then it appears I have a good SWR, correct?
However, it shows only 2.27W. The unit advertises 10W. Is this normal? Is there a simple way to increase this?
4 answers to this question
Mine showed around 4.6W, when piped through an MFJ UHF watt/swr meter and into the mag-mount antenna that came with an MXT-115.. But since I don't have a calibrated source to compare the meter against...
Hmm -- that frequency readout shows a 1kHz offset, first channel should be .550 ? Meter or radio calibration?
