Are the only differences (besides the obvious larger heat sink of the 880H) on these two radios just the RF MOSFET Amplifier Module and the extra voltage regulator on the 880? Am I missing something else?
I bought a non working 880H and was able to get it to power on by replacing a diode, a capacitor and the one voltage regulator, but there is no audio and no power coming from the antenna, even though it is transmitting and receiving. I started looking at the two and those are the only differences that I see. Seems weird that the lower power 880 has the 2 voltage regulators where the 880H just has the one. Also, any idea why the 880 has no audio and no power coming from the antenna wire (I tried external speaker and had swr?watt meter attached to antenna wire with zero SWR and zero watt output - even though when I transmit, it is being picked up on an ht nearby) Another thing too, even though the display works on the 880H, the LED's don't
Also, don't mind those extra wires. I was testing these radios as RX radios in a portable repeater
Flameout
28 answers to this question
