WRUN231 Posted October 9, 2022 Posted October 9, 2022 A regular radio is just not an option in a vehicle that cant be secured. So the Midlands make for a good option. And the installs are so clean. gortex2 1 Quote
gortex2 Posted October 9, 2022 Posted October 9, 2022 Looks nice. I miss the space the TJ had there for a jack. the JK has no room. I have no top or doors on the JK and have long given up worrys about someone stealing stuff. Quote
H8SPVMT Posted October 10, 2022 Posted October 10, 2022 Couldn't you put the radio behind the glovebox and route the plug between the box and the console (down low)? Quote
gortex2 Posted October 10, 2022 Posted October 10, 2022 Thats basically what I did in the JK. Its behind the console and cord is pulled out around. Would have liked a cleaner install but it works fine for the purpose. I have a CM760 CB that is the same on the other side of the console. Quote
WRUN231 Posted October 11, 2022 Author Posted October 11, 2022 18 hours ago, gortex2 said: Thats basically what I did in the JK. Its behind the console and cord is pulled out around. Would have liked a cleaner install but it works fine for the purpose. I have a CM760 CB that is the same on the other side of the console. And when youre a velcro junkie you stick your CB to your GMRS radio Quote
Wrvq441 Posted January 9, 2023 Posted January 9, 2023 How did you mount your antenna to your Jeep and obtain a decent ground plane? Quote
OffRoaderX Posted January 10, 2023 Posted January 10, 2023 1 hour ago, Wrvq441 said: How did you mount your antenna to your Jeep and obtain a decent ground plane? The antennas on both my Jeeps (LJ and JK) are mounted on the tailgate. Not a perfect groundplane but plenty 'good enough'. Quote
