jenksjr Posted November 3, 2022 Posted November 3, 2022 Anyone know if there is an adjustment for the microphone gain? Quote
0 KAF6045 Posted November 4, 2022 Posted November 4, 2022 6 hours ago, jenksjr said: Anyone know if there is an adjustment for the microphone gain? Do you mean the Midland MXT-115? No adjustment that I know of... Note: the MXT-115 operates in NFM mode only (ie; FRS compatible bandwidth), not GMRS (wide) FM. That is going to affect the tonal qualities on receivers depending upon the bandwidth they are operating at. AdmiralCochrane 1 Quote
0 kidphc Posted November 5, 2022 Posted November 5, 2022 Ditto don't think there are gain settings. Guess the closest you will get is to adjustments is how far is the mic from your mouth. Could shove cotton in the mic hole to lower modulation or drill the hole to increase modulation. I prefer just moving the mic. AdmiralCochrane 1 Quote
0 jenksjr Posted November 17, 2022 Author Posted November 17, 2022 Thanks for the replies. I was actually trying to reduce modulation. I just need talk very soft to keep it down. Quote
0 KAF6045 Posted November 17, 2022 Posted November 17, 2022 Holding the microphone to the side of the mouth might be a solution. It should cut down on "plosives" (the initial puff of air for P, B, V, et al) Granted, it is a dynamic mic element to my knowledge, so may still be sensitive. If you look at head sets using condenser elements you'll most often find the end of the microphone is positioned at the corner of the mouth or even just behind it. Quote
jenksjr
4 answers to this question
