MTX-115 Over Modulation
jenksjr
4 answers to this question
6 hours ago, jenksjr said:
Anyone know if there is an adjustment for the microphone gain?
Do you mean the Midland MXT-115?
No adjustment that I know of... Note: the MXT-115 operates in NFM mode only (ie; FRS compatible bandwidth), not GMRS (wide) FM. That is going to affect the tonal qualities on receivers depending upon the bandwidth they are operating at.
Link to comment
Share on other sites
Holding the microphone to the side of the mouth might be a solution. It should cut down on "plosives" (the initial puff of air for P, B, V, et al)
Granted, it is a dynamic mic element to my knowledge, so may still be sensitive. If you look at head sets using condenser elements you'll most often find the end of the microphone is positioned at the corner of the mouth or even just behind it.
Link to comment
