Some fantastic info on coax, very informative. But why when you buy a GMRS radio that comes with and antenna is the coax so tiny?
OK, On to my question, how far apart should the base antennas be for CB 27Mhz 11 M and Gmrs 462--467 MHz both are vertical with ground plane. Both will be around 60 ft. I will probably never transmit on both at the same time but I don't want bleed over. I know the coax used will have alot to do with that too.
WRPQ991
I had BW instead of Freq..
3 answers to this question
