Power Supply for Wouxun KG-XS20G Plus
WRPG818
5 answers to this question
10 minutes ago, MichaelLAX said:
Will you connect by cigarette lighter plug or direct wiring? Will you connect anything else?
Looks like it says only 4.5 amps on the direct wiring; is this it:
Yes. This is it. This is be used only for the Radio and what ever is best. Cigarette Lighter right now
In that case it is probably ok for 20 Watts.
Consider future-proofing if you have not purchased it yet (or can return it for a full refund).
For example I purchased my power supply (JETSTREAM JTPS32MAB 30 amp now priced at around $90) some years ago to power my Yeas FT-857d and now I can run that on the direct wiring and at the same time run my Radioddity DB20-G through the cigarette lighter plug connected to the Anderson Powerpoles.
I am sure there are better newer options, too:
