Luish19779 Posted January 15, 2023 Report Posted January 15, 2023 I GOT 2 XTL2500 MOTOROLA RADIO. I GOT GOOD COAX CABLE ,ANTENNA. I KNOW I NEED THE DUPLEX,BUT I DON'T KNOW WHICH ONE. AND I KNOW NEED SOMETHING ELSE. Quote
0 Lscott Posted January 15, 2023 Report Posted January 15, 2023 If you're looking to get some detailed info the below site has a lot to look at. It would be worth your time to check it out. Also people here that have been down this road before can supply good recommendations. http://www.repeater-builder.com/rbtip/index.html Luish19779 and WRUS537 2 Quote
0 gortex2 Posted January 15, 2023 Report Posted January 15, 2023 So the xtl2500 is an good radio. I would not use them for a repeater as you can sell one and get 3 or 4 CDMs or M1225 for the price...but... Your going to need to use J2. Also be advised some versions of that radio had an active high and not active low for the COR pin. Nothing is programmable on J2 and its fixed. Pins are still available online. As said you need a duplexer and a controller of some sort. Luish19779 1 Quote
0 Luish19779 Posted January 19, 2023 Author Report Posted January 19, 2023 I change my mind. The repeater are going with MCS2000 … some people told me the same and is true. Quote
0 Luish19779 Posted January 19, 2023 Author Report Posted January 19, 2023 I know that site of repeater, but I don’t have the knowledge of cable on pin,etc. If you guys help me, when came to NYC , are welcome to use or by online. I have plan to fix all that later… Quote
Luish19779
4 answers to this question
