WRVM812 Posted January 18, 2023 Report Posted January 18, 2023 Authentic Nagoya RB-MJPL Strong Mobile Mag Mount Base (UHF Female) This magnetic mount, magnet is loose in the base. Am I missing something here. Signed: Old Man WRVM812 Quote
WRQC527 Posted January 18, 2023 Report Posted January 18, 2023 In theory, nothing in the base should be loose, but to determine the problem, you might need to peel off the Mylar film. It could be some kind of glue holding the magnet, or maybe the antenna mount itself secures the magnet. Or both. Or if you can, send it back and get one that didn't fail quality control. Lscott 1 Quote
WRVM812 Posted January 18, 2023 Author Report Posted January 18, 2023 Thank you WRQC527 for your reply. I greatly appreciate it. WRQC527 1 Quote
WRQC527 Posted January 19, 2023 Report Posted January 19, 2023 Bear in mind that once you peel off the Mylar, it might be tricky to put it back on. It also might be a problem getting it off without damaging it. Hence my suggestion to try returning it if you can. Quote
Lscott Posted January 19, 2023 Report Posted January 19, 2023 12 hours ago, WRQC527 said: Bear in mind that once you peel off the Mylar, it might be tricky to put it back on. It also might be a problem getting it off without damaging it. Hence my suggestion to try returning it if you can. I've pealed off the Mylar on a bunch of magnet mounts. A good replacement is using some of the aluminum duck tape you can buy at the home improvement store. It sticks like crazy and is easy to trim off using a sharp blade. Also being aluminum it helps couple the antenna to the metal roof. WRQC527, PACNWComms, WRUU653 and 1 other 3 1 Quote
WRQC527 Posted January 19, 2023 Report Posted January 19, 2023 1 hour ago, Lscott said: aluminum duck tape Great idea. I have a couple of mag mounts myself I need to re-mylar. I don't use mag mounts much anymore except when I go hamming or GMRSing in my beater Ranger. Quote
PACNWComms Posted January 20, 2023 Report Posted January 20, 2023 The aluminum tape idea is great. I have experienced many magnet mounts being thrown away before anyone had a look under that mylar. In Hawaii I took some off and saw that every mount had the center conductor corroded off underneath. I ended up re-soldering them and putting them back into service. Well, at least the ones that were not too corroded apart in other areas as well. These were mostly Laird brand. A co-worker used gutter tape (tar and foil based) available at the big box home improvement store across the street from Pier 34 in Honolulu. WRQC527 and SteveShannon 2 Quote
