WRUF427 Posted February 2, 2023 Posted February 2, 2023 Hi this is WRUF427 I am looking for open or ask permission repeaters for upstate ny loch sheldrake ny / Liberty county ny someone is useing repeater 17 I don’t know the name for that repeater please help I’m still new to Gmrs Thanks WRUF427 Quote
Borage257 Posted February 2, 2023 Posted February 2, 2023 Have you checked the MYGMRS map with “Stale” and “Offline” repeaters turned on? WRUU653 1 Quote
gortex2 Posted February 2, 2023 Posted February 2, 2023 In that area there is not much of anything. There was a guy in liberty with a "simplex" repeater but it shows offline. Being in the catskill park there is alot of good locations but not many that allow repeaters. AKD park is similar. Unless you find someone that wants to put one up on their mountain top house you will be limited. WRUF427 1 Quote
WRUF427 Posted February 13, 2023 Author Posted February 13, 2023 In that area there is not much of anything. There was a guy in liberty with a "simplex" repeater but it shows offline. Being in the catskill park there is alot of good locations but not many that allow repeaters. AKD park is similar. Unless you find someone that wants to put one up on their mountain top house you will be limited. You know the name of that simplex repeater?Sent from my iPhone using Tapatalk Quote
WRUF427 Posted February 13, 2023 Author Posted February 13, 2023 Have you checked the MYGMRS map with “Stale” and “Offline” repeaters turned on?Yes Sent from my iPhone using Tapatalk kmcdonaugh 1 Quote
kmcdonaugh Posted February 13, 2023 Posted February 13, 2023 MyGMRS and repeaterbook are the two I keep an eye on. WRUF427 1 Quote
WRUF427 Posted February 13, 2023 Author Posted February 13, 2023 MyGMRS and repeaterbook are the two I keep an eye on.Same here but still Nonthing Sent from my iPhone using Tapatalk Quote
gortex2 Posted February 14, 2023 Posted February 14, 2023 16 hours ago, WRUF427 said: You know the name of that simplex repeater? Sent from my iPhone using Tapatalk The only one that showed up was the one you put on the page. The closest per the map to you is probably crawford but doubt you can get to it from your location. Your in an area that is almost impossible to put up a tower unless its private land and even then the APA will block it like crazy. Your only option is to find a friend on a summit of one of the hills and see if they will put one up on a roof of a house or garage. You'd have a little better luck on ham radio but not much. WRUF427 1 Quote
WRUF427 Posted February 14, 2023 Author Posted February 14, 2023 The only one that showed up was the one you put on the page. The closest per the map to you is probably crawford but doubt you can get to it from your location. Your in an area that is almost impossible to put up a tower unless its private land and even then the APA will block it like crazy. Your only option is to find a friend on a summit of one of the hills and see if they will put one up on a roof of a house or garage. You'd have a little better luck on ham radio but not much. Ohh ok thanks for helping me I guess I’ll wait to see if Crawford repeater opens if it’s fine I’ll just wait for the summer when I go to the city for fishing Sent from my iPhone using Tapatalk Quote
