Kc9pqt Posted February 9, 2023 Report Posted February 9, 2023 Good evening y'all got a question. If any of you all hooked one of these up before I got a Motorola r 1225 repeater that I would like to hook this controller too. I would like to know how and what I need to do for programming the repeater to make this work. I appreciate all who come back. Been working on this for a couple hours zetron 37 repeaterman controller I'm pretty sure I got the pins where they need to go to hook it up. When I press the disable button on controller status light goes off and transmit light engage. It has a constant carrier keying up the repeater no audio when trying to transmit through it either. Hopefully somebody on here could give me a pinout diagram to hook this up and also what to program into the repeater I tried different things and still doing the same results. Thank you Quote
gortex2 Posted February 9, 2023 Report Posted February 9, 2023 I would start here - https://www.repeater-builder.com/motorola/r1225/pdf/motorola-r1225-sm-6880905z53-o.pdf https://www.repeater-builder.com/zetron/pdfs/zetron-37-manual.pdf https://www.yumpu.com/en/document/read/41757881/motorola-r1225-gr1225-repeaterpdf-the-radioreferencecom-forums Basically you need to reprogram the repeater for General I/O. Both TX RX with CSQ. Flat Audio out and most importantly Repeater with External Controller. After getting the GR done you need to make sure dip switches and programming is right on the Zetron. SteveShannon and Radioguy7268 1 1 Quote
