TidRadio TD-H5 Software Shift +-
Hello all, I have a quick question about the software for the TidRadio TD-H5. I downloaded the software from the manufacturer website, the problem I seem to be having is the shift +- setting in the software it seems to be grayed out or locked. I read the pdf and it's not really clear on this. Now on the radio itself I found the setting and got it to work. But I would rather use the software if possible. Thanks
1 answer to this question
Per the manual all frequencies are all ready hard coded. It says 8 repeater then 24 additional repeater channels. One of the pages showed these labeled as DIY with a number. It appears all you can do is put a tone in it.
