Charliewreq466 Posted March 23, 2023 Report Posted March 23, 2023 HI THERE: I AM PROGRAMMING A UHF MOTOROLA MTS2000 HANDIE TALKIE AND IN ONE REPEATER CHANNEL THAT USES A DPL 246 TONE,WHEN I CLICK TO SELECT IT IN THE LIST OF THE DPL TONES THERE IS NO 246 DPL TONE.DOES ANYBODY KNOWS HOW TO DO IT ???? HELP NEEDED HERE..... THANKS YOU IN ADVANCE Quote
wayoverthere Posted March 23, 2023 Report Posted March 23, 2023 (edited) 1 hour ago, Charliewreq466 said: HI THERE: I AM PROGRAMMING A UHF MOTOROLA MTS2000 HANDIE TALKIE AND IN ONE REPEATER CHANNEL THAT USES A DPL 246 TONE,WHEN I CLICK TO SELECT IT IN THE LIST OF THE DPL TONES THERE IS NO 246 DPL TONE.DOES ANYBODY KNOWS HOW TO DO IT ???? HELP NEEDED HERE..... THANKS YOU IN ADVANCE Does the list have DPL 523? This thread suggests 523 with the "invert" option checked can take the place of normal DPL 246. https://forums.radioreference.com/threads/inverted-cdcss-dpl-conversion-chart.8261/ Edited March 23, 2023 by wayoverthere fix typo WRUU653 and SteveShannon 2 Quote
Charliewreq466 Posted March 23, 2023 Author Report Posted March 23, 2023 Hi There: Thanks for the fast reply but it doesn't have the 523 value..... Also I tried to erase the value on the DPL tone box and write the new value manually but it doesn't erase. it stays blue then I click the Backspace key and don't erase.... Quote
SteveShannon Posted March 23, 2023 Report Posted March 23, 2023 Unfortunately, not all radios have all digital codes. DPL 246 is not standard to Motorola. This page shows some others.: https://www.repeater-builder.com/tech-info/pl+dpl/pl+dpl.html WRUU653, wayoverthere and Charliewreq466 2 1 Quote
wayoverthere Posted March 23, 2023 Report Posted March 23, 2023 With neither 246 or 523 being on the list... I'd be tempted to take a shot in the dark and try 245 and 532 inverted, just to see if there may be a typo in the repeater info. (Kind of a long shot, I know) Charliewreq466 1 Quote
axorlov Posted March 23, 2023 Report Posted March 23, 2023 +246, +542, +653, -523, -647, -726 all are the same code. But it's unlikely Motorola will have any of them. More info here: https://web.archive.org/web/20220331074737/https://www.onfreq.com/syntorx/dcs.html wayoverthere, Lscott, Charliewreq466 and 1 other 3 1 Quote
Lscott Posted March 24, 2023 Report Posted March 24, 2023 On 3/23/2023 at 12:05 PM, axorlov said: +246, +542, +653, -523, -647, -726 all are the same code. But it's unlikely Motorola will have any of them. More info here: https://web.archive.org/web/20220331074737/https://www.onfreq.com/syntorx/dcs.html Thanks for the link. It was a long but very detailed explanation of DCS codes. I’ll have to print it to a PDF file and save it in my electronic document library. Quote
axorlov Posted March 24, 2023 Report Posted March 24, 2023 For some reason the original link (https://www.onfreq.com/syntorx/dcs.html) does not work, great thing we have Wayback Machine! Charliewreq466 1 Quote
Lscott Posted March 25, 2023 Report Posted March 25, 2023 For those that want a PDF version see attached file. DPL _ DCS Squelch System.pdf Charliewreq466, SteveShannon and axorlov 2 1 Quote
