Guest Jess Posted March 26 Report Share Posted March 26 Picked up another UV82-HP from BTECH to add to my other 82's. Programmed the radio with the same freqs that my other radios have with CHIRP. Radio receives from my other radios but will not transmit. *Warning- I am not a radio expert, nor am I a smart man. LOL. When the PTT button is depressed the selection arrow will move indicating the PTT A or PTT B being pushed, but no backlight and no transmit power icon in the upper LH corner. There is also no audible tone either, telling me that I can't transmit. Is this radio just locked from transmitting, or is there something wrong with the actual unit itself? Thanks again and go easy on me. Quote Link to comment Share on other sites More sharing options...
WRWG609 Posted April 4 Report Share Posted April 4 I had something similar. I am no expert. Try switching the VOX setting. Seemed to help me. You may need to do more than once. Good Luck! Quote Link to comment Share on other sites More sharing options...
Sshannon Posted April 4 Report Share Posted April 4 On 3/26/2023 at 12:08 PM, Guest Jess said: Picked up another UV82-HP from BTECH to add to my other 82's. Programmed the radio with the same freqs that my other radios have with CHIRP. Radio receives from my other radios but will not transmit. *Warning- I am not a radio expert, nor am I a smart man. LOL. When the PTT button is depressed the selection arrow will move indicating the PTT A or PTT B being pushed, but no backlight and no transmit power icon in the upper LH corner. There is also no audible tone either, telling me that I can't transmit. Is this radio just locked from transmitting, or is there something wrong with the actual unit itself? Thanks again and go easy on me. What frequency are you trying to transmit on? Quote Link to comment Share on other sites More sharing options...
