  On 5/15/2024 at 12:12 PM, tweiss3 said:
From what I understand, local computer programming has been available for quite a while, however, the intilization of the APXNext requires connection to the cloud for activation, then you have enable local programming, then you can program with your computer like normal. It's not very desirable.
That would make sense. I knew the only place feature could be added was on the cloud.
Expand
The radio now ships with both enabled if ordered properly. If not it takes all of 15 seconds to get into radio central change the mode and push the job. In reality many folks that have the NEXT use it for SC and LTE with RC is just fine for what it is. If your not using the LTE function for mapping, tracking or SC then there really isn't a need to order a NEXT. The 8000 does everything and then some. There are many customers who prefer the Radio Central cloud version as it gives you the ability to change the radio on the fly from anywhere in LTE coverage. Even if an agency has RM to build a network to cover a state or country in wifi is not economical. LTE makes that function pretty simple. I can sit in any state in the US as long as I have LTE and push a file to my radio. If not I'll hook up the cable. Im not saying joe volunteer firefighter with 26 calls a year needs that function but can definately see where large agencies can benefit.
