WRUU653 Posted April 19, 2023 Report Posted April 19, 2023 After 15 minutes of use and at least once every 15 minutes thereafter during a series of transmissions lasting more than 15 minutes. Many repeaters will transmit the ID without tones so if you listen with the receive tones set you won’t hear the ID. Which is nice because it doesn’t interfere with your talking. Templeton and SteveShannon 2 Quote
WRUU653 Posted April 19, 2023 Report Posted April 19, 2023 20 minutes ago, Templeton said: Ah, interesting. How often does that typically happen? Or how often is it required (by FCC ?) for that to happen? for more details… https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E/section-95.1751 Templeton and SteveShannon 2 Quote
Templeton Posted April 19, 2023 Report Posted April 19, 2023 44 minutes ago, WRUU653 said: After 15 minutes of use and at least once every 15 minutes thereafter during a series of transmissions lasting more than 15 minutes. Many repeaters will transmit the ID without tones so if you listen with the receive tones set you won’t hear the ID. Which is nice because it doesn’t interfere with your talking. Makes sense, I will try that! Thanks for filling me in. WRUU653 1 Quote
WRUU653 Posted April 19, 2023 Report Posted April 19, 2023 1 minute ago, Templeton said: Makes sense, I will try that! Thanks for filling me in. The advantage of not setting receive tones is you’ll hear other transmissions regardless if they are through the repeater or simplex. This can help avoiding stepping on someone else’s transmission. You can always use the monitor button to make sure the channel is clear also. Just some thoughts and options. SteveShannon 1 Quote
Templeton Posted April 19, 2023 Report Posted April 19, 2023 20 minutes ago, WRUU653 said: The advantage of not setting receive tones is you’ll hear other transmissions regardless if they are through the repeater or simplex. This can help avoiding stepping on someone else’s transmission. You can always use the monitor button to make sure the channel is clear also. Just some thoughts and options. Yeah, so far, I have left receive tones off so I can hear what else is happening on the freq. It is not hard for me to wait until the other transmissions are over, I was just more curious what the burst of beeps was. WRUU653 1 Quote
Bande1 Posted April 24, 2023 Report Posted April 24, 2023 On 4/8/2023 at 9:22 PM, BoxCar said: You can always ask them to repeat their call sign a little slower so you can log it. Also ask if they're properly masked. Quote
Guest Dmouse Posted June 30, 2023 Report Posted June 30, 2023 On 4/16/2023 at 9:19 PM, Guest Talljeffd said: Really enjoyed reading that back and forth. Just got my GMRS license. Navigating the fcc website was a hoot. I had always been sort of interested in ham, but the process was off-putting. I "discovered" GMRS while looking into ham. I am looking forward to the relaxed nature of GMRS. I am prior military, so I will throw the occasional phonetic out there, but the fact that it is not necessary is nice. When I was in the military I/we liked to respond to radio checks with whiskey whiskey tango tango golf bravo-wall to wall and treetop tall good buddy. Maybe that will catch on. And, I laughed out loud when I saw "uma uma". TO say the FCC site is a "hoot" is an understatement! Quote
