gscanter Posted April 6, 2023 Report Posted April 6, 2023 Is there someone who has a computer that will download a complete list of Part 95 authorized radios? I cannot get the FCC site to ever download. (And you may not get it to work either.) Or maybe someone has a full list that was created and saved when the website still wokred? WQLP990 Quote
BoxCar Posted April 6, 2023 Report Posted April 6, 2023 Without being more specific a complete list would span DECADES of approvals and that could be over a 1000 units. gscanter, gortex2 and kc9pke 3 Quote
73blazer Posted April 6, 2023 Report Posted April 6, 2023 If you use too broad of search terms, it's usually times out. Like if you just fill in part95e and hit search. Eventually you will get lucky though and it'll come thru. If you refine the search a bit more it usually works better. kc9pke and gscanter 2 Quote
73blazer Posted April 6, 2023 Report Posted April 6, 2023 Put in a date range (I put 01/01/2000 to 04/05/2023), application purpose of original grant and frequency range 462 to 468 uncheck exact, and rule part 95e and it comes up with a list of 239 radios Quote
gscanter Posted April 6, 2023 Author Report Posted April 6, 2023 Thanks, I have not used the site before, so thanks for the information. Quote
73blazer Posted April 6, 2023 Report Posted April 6, 2023 Note that the first 3 or 5 chars of the FCCID are the manufacturer code, and everything past that is manufactuer specified, some use the radio model number like Retivus, some just number their grants, like Wouxun does just WOUXUN19,WOUXUN20,WOUXUN21 etc, the 935G is WOUXUN26 so your gonna have to look at the actual grant document (change results to html and you'll get clickable links to the related docs) to find any model number it relates to. You also may get additional results by changing the application purpose to one of the permissive change ones as they tend to get a change grant and not original grant on an existing radio if it's really not much different, like a 935G plus. WRUU653 1 Quote
axorlov Posted April 6, 2023 Report Posted April 6, 2023 Some short lists were in these two threads: Quote
