oldjeep30 Posted July 29, 2023 Report Posted July 29, 2023 My jeeps alternator is charging at 14.7 volts. will this hurt my kg1000g+ with this voltage it puts out more watts. Quote
0 Lscott Posted July 29, 2023 Report Posted July 29, 2023 1 hour ago, oldjeep30 said: My jeeps alternator is charging at 14.7 volts. will this hurt my kg1000g+ with this voltage it puts out more watts. No. Generally mobile equipment is designed to operate at a nominal 13.8VDC plus or minus 15 percent at most. That would be nearly 16VDC on the high side. Take a look at the manual at the following link. https://www.buytwowayradios.com/downloads/dl/file/id/1411/product/5287/wouxun_kg_1000g_owners_manual.pdf Look at page 80. WRUU653, WRXB215, WRXH357 and 1 other 4 Quote
oldjeep30
1 answer to this question
