Tommy2watts Posted August 6, 2023 Report Posted August 6, 2023 Hello to all of you. I'm new to GRMS. I need to know the best antenna for my Cadillac SRX. I'm NOT going to drill holes in my car. I'm looking for a lip mount that nicely fits the back hatch. The handheld radio is Wouxun KG-935-G PLUS. So the coax must fit the radio also. The antenna can't be tall because of the garage door and car washes. I am looking for HELP. Tommy2watts WRME377 Chicago Quote
WRQC527 Posted August 6, 2023 Report Posted August 6, 2023 This is roughly the setup I use on my Sienna so I can fit in the garage. In order to connect this to your HT you would also need the adapter. This is certainly not the only setup you could use, I'm sure others will chime in. This, as I like I say about instruction manuals, is just how one guy does it. https://www.dxengineering.com/parts/cma-cp-5nmo https://www.ruggedradios.com/collections/mobile-antennas/products/point5-gmrs-antenna https://www.amazon.com/DHT-Electronics-Handheld-Antenna-Quasheng/dp/B00COKNKS8/ref=asc_df_B00COKNKS8/?tag=hyprod-20&linkCode=df0&hvadid=309707619534&hvpos=&hvnetw=g&hvrand=18152382270226592541&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031580&hvtargid=pla-569717079243&psc=1 WRYF792, WRUU653, Lscott and 1 other 3 1 Quote
WRUU653 Posted August 6, 2023 Report Posted August 6, 2023 23 minutes ago, WRQC527 said: This, as I like I say about instruction manuals, is just how one guy does it. nice… WRQC527 1 Quote
Tommy2watts Posted August 7, 2023 Author Report Posted August 7, 2023 6 hours ago, WRQC527 said: This is roughly the setup I use on my Sienna so I can fit in the garage. In order to connect this to your HT you would also need the adapter. This is certainly not the only setup you could use, I'm sure others will chime in. This, as I like I say about instruction manuals, is just how one guy does it. https://www.dxengineering.com/parts/cma-cp-5nmo https://www.ruggedradios.com/collections/mobile-antennas/products/point5-gmrs-antenna https://www.amazon.com/DHT-Electronics-Handheld-Antenna-Quasheng/dp/B00COKNKS8/ref=asc_df_B00COKNKS8/?tag=hyprod-20&linkCode=df0&hvadid=309707619534&hvpos=&hvnetw=g&hvrand=18152382270226592541&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031580&hvtargid=pla-569717079243&psc=1 Thank you, WRQC527, for the help. Nice clean setup. That is what I'm looking for. WRQC527 and WRUU653 2 Quote
WRYF792 Posted August 10, 2023 Report Posted August 10, 2023 I'm currently just using a magnetic mount antenna, the cable is far too short to make it fit in my car without having the passenger choked by the cable. I'd love to have a lip mount, but I have a small sedan that doesn't really have anywhere good for a lip mount, sadly. Thinking about just just getting this antenna, I've had good luck using one in the past. And it's small! https://www.buytwowayradios.com/midland-mxta13.html Quote
