WRXX938 Posted August 22, 2023 Report Posted August 22, 2023 I just downloaded CHIRP. Found the GMRS section but ot will not allow me to upload it to my uv5r. 20230821_204601.mp4 It will only allow me to program what I pulled off the radio. This chirp format is different than what I have seen on the YouTube. Any suggestions? Quote
0 OffRoaderX Posted August 22, 2023 Report Posted August 22, 2023 Generally you download from the radio first, SAVE THE FILE, then make your changes, THEN upload.. The download confirms that you have the correct radio and comm port settings selected. Are you able to download? WRUU653, SpeedSpeak2Me and SteveShannon 3 Quote
0 WRXX938 Posted August 22, 2023 Author Report Posted August 22, 2023 Yes I have pulled from the radio. I I also have figured out what o was doing wrong. But I am trying to program the repeaters I want and it is not loading the tones or offsets. Both uv5rs work on the normal frs and gmrs. I will have to play with it more. I watched your tutorial. The interface is different and I don't see a lot of options like to one you showed 2 years ago. Quote
0 WRXX938 Posted August 22, 2023 Author Report Posted August 22, 2023 I figured out how to get things loaded onto the radio. However programming repeaters is troublesome. It is not loading the tones,offset or direction for receive. I am using the information imported from repeater book from chirp. Back to the drawing board Quote
WRXX938
It will only allow me to program what I pulled off the radio. This chirp format is different than what I have seen on the YouTube.Any suggestions?
3 answers to this question
