Extreme Posted August 30, 2023 Report Posted August 30, 2023 I have the correct programming cable and software but don't know where to find "Product ID" for software install/setup, TIA, Quote
0 SteveShannon Posted August 31, 2023 Report Posted August 31, 2023 3 hours ago, Extreme said: I have the correct programming cable and software but don't know where to find "Product ID" for software install/setup, TIA, Is it on a label beneath the battery? Quote
0 gortex2 Posted September 1, 2023 Report Posted September 1, 2023 The product ID was on the original CD from ICOM. There are Product ID's on the web if you do some searching. If you ordered the Software from ICOM it would have the ID. Extreme 1 Quote
0 Extreme Posted September 1, 2023 Author Report Posted September 1, 2023 (edited) Found it in the software and it satisfied the install but then threw me another curve ball and I stopped without the correct data it wanted. I punted and ordered a wouxun 20w unit. Kinda done with the used stuff. Seller was to program with my spreadsheet but they inserted 1-6 and none of the useful 8-23 simplex, but did get the repeaters correct. Sent it back and they returned with no changes. Maybe someone here wants an Icon 221? Edited September 1, 2023 by Extreme Add remarks Quote
0 gortex2 Posted September 2, 2023 Report Posted September 2, 2023 Channel 8-14 aren't supposed to be in mobiles so that's most likely why they didn't put them in. The rules state handhelds only. The 221 is a much more solid radio than any of the CCR units. I run them for SAR work and have yet to have one go bad. 128 channels and scan works well. Lscott 1 Quote
0 Extreme Posted September 2, 2023 Author Report Posted September 2, 2023 4 hours ago, gortex2 said: Channel 8-14 aren't supposed to be in mobiles so that's most likely why they didn't put them in. The rules state handhelds only. The 221 is a much more solid radio than any of the CCR units. I run them for SAR work and have yet to have one go bad. 128 channels and scan works well. They had no issue inserting those channels in multiple Kenwood's I've purchased there. Quote
0 Extreme Posted September 3, 2023 Author Report Posted September 3, 2023 On 9/2/2023 at 3:30 AM, gortex2 said: Channel 8-14 aren't supposed to be in mobiles so that's most likely why they didn't put them in. The rules state handhelds only. The 221 is a much more solid radio than any of the CCR units. I run them for SAR work and have yet to have one go bad. 128 channels and scan works well. I mis-spoke. The channels I want that are not programmed are 15 - 22 Simplex. Quote
0 gortex2 Posted September 4, 2023 Report Posted September 4, 2023 Are you sure they didn't program a DIR button for Direct. That's how all my mobiles are setup. Worth checking. Quote
0 Extreme Posted September 4, 2023 Author Report Posted September 4, 2023 4 hours ago, gortex2 said: Are you sure they didn't program a DIR button for Direct. That's how all my mobiles are setup. Worth checking. No idea how to check that. Only 1 button does anything and that switches A-B Quote
Extreme
TIA,
8 answers to this question
