WSCC339 Posted October 8, 2024 Posted October 8, 2024 FWIW, you can flash the UV-13 Pro (Amateur Radio version of this radio) onto the GM-15 PRO and it removes the odd channel formatting. Quote
WRYS709 Posted October 8, 2024 Posted October 8, 2024 3 hours ago, WSCC339 said: FWIW, you can flash the UV-13 Pro (Amateur Radio version of this radio) onto the GM-15 PRO and it removes the odd channel formatting. Not sure what you are saying here, but in my experience the CPS code plugs created for my UV-13Pro, get corrupted when I open them up in my Pofung UV-15, which is a clone of the GM-15Pro. Quote
SteveShannon Posted October 8, 2024 Posted October 8, 2024 7 hours ago, WRYS709 said: Not sure what you are saying here, but in my experience the CPS code plugs created for my UV-13Pro, get corrupted when I open them up in my Pofung UV-15, which is a clone of the GM-15Pro. I think he’s saying to install the firmware for the UV-13 Pro into the GM-15 Pro, and then you would be able to load configuration files created with the UV-13 Pro. WSCC339 1 Quote
WSCC339 Posted October 10, 2024 Posted October 10, 2024 On 10/8/2024 at 8:26 AM, SteveShannon said: I think he’s saying to install the firmware for the UV-13 Pro into the GM-15 Pro, and then you would be able to load configuration files created with the UV-13 Pro. Pretty sure that's what I did. I don't think I used pv-15 software afterwards. I'll crack open the laptop later to confirm and type out the steps I took. Sorry! Didn't mean to cause more confusion. Quote
WRYW480 Posted October 27, 2024 Posted October 27, 2024 Radioddity Software should work. Chirp does not work on the GM-15Pro. Quote
Guest GM-15 officially supported Posted November 27, 2024 Posted November 27, 2024 https://chirpmyradio.com/issues/9798 Quote
WRYS709 Posted November 27, 2024 Posted November 27, 2024 On 10/10/2024 at 12:18 PM, WSCC339 said: Pretty sure that's what I did. I don't think I used pv-15 software afterwards. I'll crack open the laptop later to confirm and type out the steps I took. Sorry! Didn't mean to cause more confusion. I would love to hear your method of flashing UV-13Pro firmware over to the GM-30 a/k/a UV-15Pro a/k/a Pofung UV-15UV The link to Chirp by the previous "ghost" poster does list many people wanting to help out, but so far none of them has cracked the problem why Chirp does not support these radios. The Radioddity GM-30 cps programming software (windows only) does work. Quote
Guest GM-15 Pro User Posted December 23, 2024 Posted December 23, 2024 The steps to update the firmware for GM-15 Pro to become a UV-13 Pro can be found below - however, do this at your own risk. This will violate FCC's part 95E and if performed incorrectly, could brick your GM-15 Pro. I am not an expert, but I purchased two GM-15 Pro's and they are useless to me without the TX function. I spent the time learning (and bricking) my radios to provide a guide so that you don't have to Software required: Radioddity's GM-30 program (https://radioddity.s3.amazonaws.com/Radioddity GM-30 V1.05.exe) - I don't know how long Radioddity will keep this CPS file on their site. Radioddity's P15UV program (https://www.hamradioshop.pl/pliki/Baofeng/Baofeng_P15UV.zip) - I don't know how long HAM radio shop will keep this CPS file on their site. UV13-Firmware BIN file (https://chirp.danplanet.com/attachments/8905) - I don't know how long chirp will keep this BIN file active on their site Step by Step: plug the GM-15 Pro in with programming cable turn the GM-15 Pro on run the radioddity GM-30 program (mock of GM-15) read from the radio, make sure connection is working properly once read, turn the GM-15 Pro off hold PTT and flash light button (under PTT) together, turn the radio on Note: Display should be off, red light should be on - this is firmware upgrade mode in GM-30 radioddity program, go to tools - this is where you update firmware select the UV-13 Pro firmware package choose upgrade this will flash the UV-13 Pro firmware Radio will reboot itself after firmware upgrade Close GM-30 program software, it will no longer work as a GM-30 radio run the radioddity P15UV program (mock of UV-13) read from the radio, make sure this is working properly Modify the radio Write to the radio Instructions from Radioddity themself on upgrading GM-30's firmware https://www.radioddity.com/blogs/all/how-to-update-radioddity-gm-30-firmware Good luck! Quote
WRYS709 Posted December 23, 2024 Posted December 23, 2024 Nice work! I am going to start downloading immediately: thank you! Was this also successful on a Radioddity GM-30? or did it brick? Quote
Guest Guest GM-15 Pro User Posted December 24, 2024 Posted December 24, 2024 Unknown on the GM-30. I suspect it will work. From what I've read, it's a very similar codeplug and firmware, but I have not sacrificed one to determine that. Quote
WRYS709 Posted December 24, 2024 Posted December 24, 2024 Ok, thanks! I have a Pofung clone of the Radioddity GM-30 around here somewhere and I would like to open it up! My impulse buy of the Baofeng UV-12 arrived today and its a nice addition for about $21. I has the look and feel of an FRS radio at about 2-3 watts but it is their "FRS" version of a Ham Radio, and it is open. There is supposedly Baofeng software available to program it. In the meantime, I programmed it with Chirp using the Retevis RB27 designation for the Read template. Quote
WSDA629 Posted April 29, 2025 Posted April 29, 2025 On 12/23/2024 at 9:07 AM, Guest GM-15 Pro User said: The steps to update the firmware for GM-15 Pro to become a UV-13 Pro can be found below - however, do this at your own risk. This will violate FCC's part 95E and if performed incorrectly, could brick your GM-15 Pro. I am not an expert, but I purchased two GM-15 Pro's and they are useless to me without the TX function. I spent the time learning (and bricking) my radios to provide a guide so that you don't have to Software required: Radioddity's GM-30 program (https://radioddity.s3.amazonaws.com/Radioddity GM-30 V1.05.exe) - I don't know how long Radioddity will keep this CPS file on their site. Radioddity's P15UV program (https://www.hamradioshop.pl/pliki/Baofeng/Baofeng_P15UV.zip) - I don't know how long HAM radio shop will keep this CPS file on their site. UV13-Firmware BIN file (https://chirp.danplanet.com/attachments/8905) - I don't know how long chirp will keep this BIN file active on their site Step by Step: plug the GM-15 Pro in with programming cable turn the GM-15 Pro on run the radioddity GM-30 program (mock of GM-15) read from the radio, make sure connection is working properly once read, turn the GM-15 Pro off hold PTT and flash light button (under PTT) together, turn the radio on Note: Display should be off, red light should be on - this is firmware upgrade mode in GM-30 radioddity program, go to tools - this is where you update firmware select the UV-13 Pro firmware package choose upgrade this will flash the UV-13 Pro firmware Radio will reboot itself after firmware upgrade Close GM-30 program software, it will no longer work as a GM-30 radio run the radioddity P15UV program (mock of UV-13) read from the radio, make sure this is working properly Modify the radio Write to the radio Instructions from Radioddity themself on upgrading GM-30's firmware https://www.radioddity.com/blogs/all/how-to-update-radioddity-gm-30-firmware Good luck! Pardon my newbie question. What would the benefit/goal of changing the firmware? I have no intention of doing this. I don't have the experience to even consider it. RoadApple and SteveShannon 1 1 Quote
OffRoaderX Posted April 29, 2025 Posted April 29, 2025 1 minute ago, WSDA629 said: What would the benefit/goal of changing the firmware? Often times there is no benefit to most people. When asked, I generally recommend to never bother with an update unless said update fixes some specific issue that you need to be fixed. "some people" often just blindly apply any update they come across and they sometimes learn the hard way that the risk of permanently brick'ing the radio is high. RoadApple and SteveShannon 1 1 Quote
WSDA629 Posted April 29, 2025 Posted April 29, 2025 1 hour ago, OffRoaderX said: Often times there is no benefit to most people. When asked, I generally recommend to never bother with an update unless said update fixes some specific issue that you need to be fixed. "some people" often just blindly apply any update they come across and they sometimes learn the hard way that the risk of permanently brick'ing the radio is high. Makes sense. Again not a theory I'd like to test. But the temptation for the "better newer" is tough to overcome. Look at the gadgets for cars and firearms the don't really do much but look cool. RoadApple, SteveShannon and WRTC928 3 Quote
WRYU316 Posted October 8, 2025 Posted October 8, 2025 On 10/7/2024 at 10:01 PM, WSCC339 said: FWIW, you can flash the UV-13 Pro (Amateur Radio version of this radio) onto the GM-15 PRO and it removes the odd channel formatting. How do I go about doing this, cant figure it out for the life of me? Quote
WRYS709 Posted October 8, 2025 Posted October 8, 2025 19 minutes ago, WRYU316 said: How do I go about doing this, cant figure it out for the life of me? Did you follow the December 24, 2024 Guest post above? I decided not to try it and keep my Pofung UV-15 (a clone of the Radioddity GM-30) an FCC Compliant GMRS HT, since I had already purchased the UV-13Pro for $20 from AliExpress Quote
WSJW650 Posted October 11, 2025 Posted October 11, 2025 Step by step video instructions he covers the one or two additional steps for the GM15 pro *also agree with never updating if prompted (potential for device bricking is high) Quote
WRYS709 Posted October 11, 2025 Posted October 11, 2025 WoW: He's even got that "Randy look" down pat!! Quote
WSJP267 Posted October 12, 2025 Posted October 12, 2025 is the radio "CHRIP" compatable? did it come with the data cable? I only use CHIRP on my Baofeng GMRS GM21 its the best way to program a radio for me its easy to just upload a file an make adjusts as needed.. Quote
WRYS709 Posted October 12, 2025 Posted October 12, 2025 14 minutes ago, WSJP267 said: is the radio "CHRIP" compatable? did it come with the data cable? I only use CHIRP on my Baofeng GMRS GM21 its the best way to program a radio for me its easy to just upload a file an make adjusts as needed.. Yes earlier this year they cracked the code for both the Radioddity GM-30 and the DB20-G GMRS radios for Chirp! Now two good radios are great radios! Quote
