Repeater id requirements for gmrs
1 answer to this question
  On 10/27/2023 at 5:25 AM, WQXV476 said:
What are the repeater id requirements for a gmrs repeater?  Voice or CW?  How often?  What is a simple id injector for a gmrs repeater?  (Coming from knowledge of ham regs).
Expand
That’s found herein:
https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E
§ 95.1751 GMRS station identification.
Each GMRS station must be identified by transmission of its FCC-assigned call sign at the end of transmissions and at periodic intervals during transmissions except as provided in paragraph (c) of this section. A unit number may be included after the call sign in the identification.
(a) The GMRS station call sign must be transmitted:
(1) Following a single transmission or a series of transmissions; and,
(2) After 15 minutes and at least once every 15 minutes thereafter during a series of transmissions lasting more than 15 minutes.
(b) The call sign must be transmitted using voice in the English language or international Morse code telegraphy using an audible tone.
(c) Any GMRS repeater station is not required to transmit station identification if:
(1) It retransmits only communications from GMRS stations operating under authority of the individual license under which it operates; and,
(2) The GMRS stations whose communications are retransmitted are properly identified in accordance with this section.
