jsneezy Posted January 4, 2024 Report Posted January 4, 2024 Because of some troublemakers causing issues on a repeater I had just gotten access to, the group maintaining the repeater is requiring PTT-ID for all users of the repeater, as far as I can tell. They have assigned each member a 4 digit code for the PTT-ID, which will be DTMF or MDC1200. Is this going to work as a per channel setting on the radios? Or if I set it up, will it transmit the PTT-ID regardless of the channel I'm transmitting on? The radios in question are a Baofeng UV-9G and a Radioddity DB-20G. Quote
nokones Posted January 4, 2024 Report Posted January 4, 2024 My guess is if your radios have the PT-T ID feature it is radio wide feature meaning it will transmit on all channels unless the radio has the ability of programming each channel with a different personality. It is typical of CCRs to have either a single personality configuration or no PT-T feature at all. Quote
WRQC527 Posted January 4, 2024 Report Posted January 4, 2024 12 hours ago, jsneezy said: will it transmit the PTT-ID regardless of the channel I'm transmitting on? I think you should be able to set it up on a per-channel basis. I have a pair of Baofeng UV-82s that I set up with two channels. One channel has PTT-ID, one doesn't. I set them up in CHIRP within the channel settings. I wouldn't be so bold as to say this is how all radios with PTT-ID work, but that's my experience. WRXB215 1 Quote
