Kenwood TK-880H Ver2 Problem Scanning Channels
Just purchased a TK-880H and programmed all the GMRS frequencies into radio.  I used KPG-49D software and everything works perfect but I can't get it to scan.   I only have about thirty frequencies entered but it won't scan the channels.  I have only one group programmed.   Anyone have a suggestion for a change in software entries or anyother technical fix. Thanks  D. Neal WRZL870 Georgetown, KY
3 answers to this question
Expand
Not sure what Kenwood would call the feature (others more familiar with kenwood likely will), but some/many LMR radios have a feature that may be referred to as "on hook scanning". I ran into this with my vertex stuff, and the fix was to ground the mic holder button to the radio. I also had one mic where the ground wire to the button was broken, but a quick solder and it was back to normal.
  On 1/14/2024 at 3:04 AM, drexel55 said:
Thanks I will recheck setup.  I have tried the mic grounding and that did not solve the problem.
Expand
Gotcha. Settings are a definite possibility, but any chance of swapping mics with another working unit to test and rule out a fault there?
That was what clued me in on the broken wire in mine...swapping between one working and one not, and which part (cord vs mic) the problem followed.
