Knock knock sound while listening to transmissions
Tidycat
Greetings all. I'm new to GMRS and just got my FCC license a few days ago so this may be a dumb question... when I'm listening to other folks on any of the channels there's a repeating knock-knock sound during transmissions. Is this normal, and is there a setting that turns it off or is it a standard part of GMRS? Radio is a Tidradio GM-5R.
Thank you.
Link to comment
Share on other sites
13 answers to this question
  • 1
10 minutes ago, Tidycat said:
There's a cell tower about 450 yards from the property here. I get the knock-knock/tick-tock/heartbeat sound on both radios no matter where I go on the property so that seems like a likely source of the interference.
It's really difficult to know what it is.  It could be something on the power lines, or part of the cell site.  It could also be a motor controller somewhere, such as on a pump, or a power supply for some equipment you have.  A lot of times hams will turn off the power to their homes to see if such interference continues.  Then they turn on each breaker until the noise begins again in an effort to determine which circuit it's on.
Also, go somewhere else, distant from the cell tower, and see if the sound persists.
Link to comment
Thank you.
It’s not part of GMRS. It sounds like it is probably just some kind of interference. Since it’s rhythmic I would guess it’s some piece of electrical equipment somewhere.
Link to comment
Link to comment
Thank you sir for the helpful advice. I'll try turning the pump off which is the main power consumer here.
Link to comment
The standard rubber duckies on these Tidradio GM-5R's have a hex set screw mashed into the threads on the radio. They were very tight and I was actually afraid I might strip out the hole getting them loose to mount the Nagoyas, so I don't think that was the problem. And both antennas were screwed down tight.
Link to comment
I'm listening to a nice GMRS presentation on the 462.700 100.0 repeater here in Vegas and one participant's transmissions have the tick-tocks while all the others are free and clear. Not sure what's causing it but before every transmission with the rubber duckies had the tick-tocks.
Link to comment
