WSBQ451 Posted March 10, 2024 Report Posted March 10, 2024 When I'm done programming frequencies and channels and stuff using GM30 software, which folder should I save it to so that my channel list doesn't dissappear in the software? Thanks! Quote
wrci350 Posted March 10, 2024 Report Posted March 10, 2024 You can save it wherever you want. Just remember where you put it. For example, create a folder on your desktop and call it "Radio" or "GM30" and put the saved file there. Quote
WSBQ451 Posted March 10, 2024 Author Report Posted March 10, 2024 Ok sounds good. But I guess my question would be how do I get the software to list the changes that I have made? Everytime I open the software, it listes the default DIY channels. Thanks. Quote
wrci350 Posted March 10, 2024 Report Posted March 10, 2024 The really good programmers (like RT Systems) default to the last file opened. Some of the vendor-supplied ones don't do that and you have to re-open the file. If you click on "Open" you should see the name of your saved file. SteveShannon 1 Quote
WSAA635 Posted March 10, 2024 Report Posted March 10, 2024 I created a folder in my Home folder called "GMRS" and I have folders inside of that like the pic shows. It's kind of a "Russian Doll" kind of thing where there's folders inside of folders. I also save them all off to a USB stick in case of a computer mishap or if I'd like to share them with someone. Quote
WSAA635 Posted March 10, 2024 Report Posted March 10, 2024 33 minutes ago, WSBQ451 said: Ok sounds good. But I guess my question would be how do I get the software to list the changes that I have made? Everytime I open the software, it listes the default DIY channels. Thanks. I simply rename the file to what I've done to it. You can see in the above pic that I have the "Factory" UV-5R" program and then I renamed it to "Baofeng_UV-5R_GMRS_MURS_DPS_and then the date you modified it." so I know it from the factory downloaded file. Quote
