UncleYoda Posted September 25, 2025 Posted September 25, 2025 You got it! It's Menu 45. The menu choices I mentioned above are for the 5RH Pro, which I should have realized (it doesn't have the one overall numbered list like the GM5RH). I've edited the earlier post. Quote
WRYS709 Posted September 25, 2025 Posted September 25, 2025 You mentioned some "Radio ID" that deletes with the BACK button. Where do I find this; or is it on the 5RH Pro only? Quote
UncleYoda Posted September 25, 2025 Posted September 25, 2025 That's the 5RH Pro GPS menu, probably the same as what you have ordered. WRYS709 1 Quote
WRYS709 Posted September 28, 2025 Posted September 28, 2025 On 9/25/2025 at 12:01 PM, UncleYoda said: That's the 5RH Pro GPS menu, probably the same as what you have ordered. Received the 5RH Pro 2-pack (corrected typo) Not very impressed! No Chirp GPS poor capability Seems not as robust range as my other HTs including Baofengs Menu is indeed more sophisticated, but I may return them @UncleYoda: talk me out of returning them! What do you like about them? Quote
UncleYoda Posted September 28, 2025 Posted September 28, 2025 Mine with GPS are 5RH Pro not 5RM. I do have K5+ which are the 5RM type but do not have GPS and those have the red letter menu like GM-5RH. I have not done much testing with the 5RH's, except making sure GPS worked and they do receive transmissions. I've been using one K5+ for a few months and it receives good; haven't made a point of testing TX distance. My K5+'s don't have any special features that I use except airband RX. All the 5RM/5RH type screens are virtually invisible out in the sun. So I made a cheapo shading device that works (most anything will do). (I may not be here much if at all anymore, so good luck whatever you decide.) Quote
WRYS709 Posted September 28, 2025 Posted September 28, 2025 Sorry for the Typo; mine are the 5RH PRO as well Quote
WRYS709 Posted September 30, 2025 Posted September 30, 2025 Watching some 5RH PRO videos and getting more excited about these! Quote
WRYS709 Posted October 24, 2025 Posted October 24, 2025 Turns out there is modded CPS software that allows for CSV import and export for each zone for the 5RH Pro; making it much easier to program Quote
WRYY714 Posted November 14, 2025 Posted November 14, 2025 I can't seem to find an actual GM-5RH any longer. The are either the UV-5RH or the 5RM. I was loving getting the two pack of the true GM-5RH. WRYS709 1 Quote
OffRoaderX Posted November 14, 2025 Posted November 14, 2025 17 minutes ago, WRYY714 said: the two pack hxpx 1 Quote
WRYS709 Posted November 20, 2025 Posted November 20, 2025 On 10/24/2025 at 1:21 PM, WRYS709 said: Turns out there is modded CPS software that allows for CSV import and export for each zone for the 5RH Pro; making it much easier to program And works nicely on 220 with the Radioddity Tri-band antenna Quote
