WSGZ768 Posted February 7 Report Posted February 7 1 minute ago, SteveShannon said: 1. They frequently don’t work well unless they’re designed for the job. 2. Then you need a much larger duplexer. The portable repeaters have one built in. 3. Power output is vastly overrated. Range is usually limited by other factors for UHF, not power. Hmmm.... I follow ya. I just ordered my HT today. (Wouxun Q10G) Maybe by luck, there are some hidden repeaters here already and I can figure out their I/O frequencies and respected tones. If not, I'll cross that bridge with a build later. Thank you for all of your input Steve! I really appreciate it. SteveShannon 1 Quote
nokones Posted February 8 Report Posted February 8 23 hours ago, WSGZ768 said: My thoughts on the "build" for a repeater would be a couple 50W radios. Might as well go big, right? lol If you're thinking about marrying two Wouxuns together, forget about it. They have a desense problem because of the lack of shielding. I've seen maxon radios work somewhat decent and I have heard that people have married two Motorola MCS2000 with decent results. I haven't heard if anyone has tried a couple of XTLs. It would be best just getting a real repeater that has the correct duty cycle. SteveShannon and WSGZ768 2 Quote
WRTC928 Posted February 10 Report Posted February 10 I don't remember who makes it, but someone makes a mobile/base radio that's actually designed so you can plug two of them together and have a repeater. That's an intriguing concept. Quote
SteveShannon Posted February 10 Report Posted February 10 7 minutes ago, WRTC928 said: I don't remember who makes it, but someone makes a mobile/base radio that's actually designed so you can plug two of them together and have a repeater. That's an intriguing concept. The KG1000G is marketed that way. @OffRoaderX tried it. It worked, but not as simply as it was marketed. He has three or so videos on YouTube as Notarubicon about it. WRTC928 1 Quote
DeuceoneRadio Posted May 6 Report Posted May 6 I got my GMRS license not too long ago. It's still kind of quiet but I don't care about talking to strangers. If it happens then cool. I got it for my family but we're so spread out that a few repeaters in the area would be absolutely fantastic. I'm actively working on a proposal for the company I work for in Blanchard to see if they would sponsor a repeater on site. It would probably be a hard sell since its a multi-national corporation but it never hurts to try. I would love to work with a few entities for sponsorship to put up a few across the Shreveport/Bossier area. Quote
WRUE951 Posted May 6 Report Posted May 6 The KG1000 radios defiantly has issues working as a repeater and they are difficult to implement a controller due to pin out access.. People wanting to go the route of making a repeater with two radios should consider a pair for Maxon 8402 radios. Like the KG1000's the Maxons are designed to pair with a simple jumper cable to make them work in repeater fashion. The Maxons are real commercial radios and will offer a more robust setup for the same dollars spent on the kg1009's. BTW, the Maxon Radios are the same used in the Brigecomm Repeaters. Quote
MJR346 Posted June 17 Report Posted June 17 Funny thing is, I'd love to put a repeater up in my area, but no place to put one high up that doesn't want $300/month rent. New Orleans and Baton Rouge have repeaters , funny is 600 in New Orleans, 650 on Northshore, and 700 in Livingston are only repeaters I hear traffic on. But do agree, rest of Louisiana basically has zero repeaters. However finding lots of ham radio clubs building GMRS repeaters for people to use as 3 in New Orleans area are run by ham clubs . Quote
WRUE951 Posted June 17 Report Posted June 17 On 5/6/2025 at 7:31 AM, WRUE951 said: The KG1000 radios defiantly has issues working as a repeater and they are difficult to implement a controller due to pin out access.. People wanting to go the route of making a repeater with two radios should consider a pair for Maxon 8402 radios. Like the KG1000's the Maxons are designed to pair with a simple jumper cable to make them work in repeater fashion. The Maxons are real commercial radios and will offer a more robust setup for the same dollars spent on the kg1009's. BTW, the Maxon Radios are the same used in the Brigecomm Repeaters. It looks like BuyTwoWayRaidos came up with two solutions making it easier to implement a controller and or an Auto CW board to the KG1000 Radios Just got an emial from them today giving the details. https://www.buytwowayradios.com/blog/2025/06/two-new-products-to-auto-id-your-wouxun-kg-1000g-uv980p-repeater-systems.html?utm_source=E20250616-13&utm_medium=email&utm_campaign=E20250616-13 Quote
