WSCU736 Posted May 22, 2024 Report Posted May 22, 2024 I hear all the time repeaters coming in on 18-19 GMRS channels. Why is this? Quote
1 kidphc Posted May 22, 2024 Report Posted May 22, 2024 Repeater outputs are the simplex frequencies Sent from my SM-S901U using Tapatalk WRXB215, amaff and SteveShannon 2 1 Quote
0 WSCU736 Posted May 22, 2024 Author Report Posted May 22, 2024 2 minutes ago, kidphc said: Repeater outputs are the simplex frequencies Sent from my SM-S901U using Tapatalk Okay so this is normal... Thanks kidphc 1 Quote
0 amaff Posted May 22, 2024 Report Posted May 22, 2024 1 minute ago, kidphc said: Repeater outputs are the simplex frequencies That. The only thing that changes for a repeater is *your* transmit frequency (IE: the frequency the repeater is listening on). But it's re-transmitting on your receive frequency. If you don't want to hear 'em, you can put a Rx CTS or DCS tone on your radio on those channels (same way if you have a repeater programmed on one of those channels, you won't hear simplex traffic on that channel unless they are using the same tone as the repeater) SteveShannon 1 Quote
0 WSCU736 Posted May 22, 2024 Author Report Posted May 22, 2024 42 minutes ago, amaff said: That. The only thing that changes for a repeater is *your* transmit frequency (IE: the frequency the repeater is listening on). But it's re-transmitting on your receive frequency. If you don't want to hear 'em, you can put a Rx CTS or DCS tone on your radio on those channels (same way if you have a repeater programmed on one of those channels, you won't hear simplex traffic on that channel unless they are using the same tone as the repeater) So, if I put the PL tone on both TX and RX I wont hear the GMRS simplex? Quote
0 amaff Posted May 22, 2024 Report Posted May 22, 2024 16 minutes ago, Jasper said: So, if I put the PL tone on both TX and RX I wont hear the GMRS simplex? TX won't matter on a simplex channel (unless you're trying to talk to someone who's listening for that tone). But yes, unless they're transmitting the tone you put on the RX side, your radio just won't open the speaker, essentially. You can look at it and see that it's receiving, but it won't make it through the radio to the speaker. WSCU736 1 Quote
0 WRXB215 Posted May 22, 2024 Report Posted May 22, 2024 1 hour ago, Jasper said: So, if I put the PL tone on both TX and RX I wont hear the GMRS simplex? Short answer: correct. WSCU736 and amaff 2 Quote
WSCU736
6 answers to this question
