Solved: Baofeng UV5R-8W programming /Model menu in Chirp Next= use model BF-F8HP as an alternative.
Just an FYI
Since the UV5R-8W  was not listed in the Chirp Next drop-down menu today...
I tested/used the BF-F8HP selection. That allowed all 3 Power settings to be selected during programming,  instead of the 2 power settings as recognized for the UV5R drop-down model choice.
It's alive!😀
I hope this helps someone.
UPDATE Today 03-31-25:
RE:  Programming change - UV-5X
HX: I purchased two of these radios together/ same purchase, but never opened the 2nd UV5R-8W until just today.
The #1 unit above has been/is still working great. Unit#1  has been updated with several new channels numerous times. Unit #1 is always updated using that saved BF-F8HP Chirp code plug--since the beginning.
However, I just tried to copy that same working code plug into my Unit#2 and discovered a minor issue.  A trial of full factory resets and numerous edits in Chirp did solve this issue.
Everything else transferred correctly to Unit#2 and the radio worked well ---except the Power-up Message--- it would not display my call signs to match Unit#1 and always reverted to WELCOME.
Thus, I found a Baofeng page that advised me to use UV5X for Chirp.  I then read the radio (Unit#2) as a UV5X, then entered the call signs in this new UV5X Chirp code plug,  and uploaded it to Unit #2.
All is now working as desired.
Update 4/18/25
I reverted to using the  BF-F8HP selection in Chirp again to access all the power (1-5-8) levels this radio supports. The UV-5X selection limits the radio to Low and High only.
I've been using chirp for my UV-5R8W for a few months now. I can't remember what I chose in the menu but it wasn't the BF-F8HP. If I have time during lunch today, I'll open chirp and get the radio out of the truck and see if I can figure out what I used. I haven't messed with it in a while.
I’ve been using a few uv5r-8w radios for a year or so.  I just use uv5r. No muss no fuss.
