cdesigns Posted October 26, 2016 Posted October 26, 2016 467.5750 467.6000 467.6250 467.6500 467.6750 467.7000 467.7250 So we are licensed to transmit on this frequencies and receive 5mhz lower on a repeater setup right? But can we TX/RX on those 467mhz frequencies Simplex mode TX and RX on 467mhz? I'm looking for just a little more privacy when traveling and stay away from bubble pack GMRS people It should be legal right? Durake 1 Quote
jwilkers Posted October 26, 2016 Posted October 26, 2016 No. These frequencies are not legal for simplex comms. AntiSquid Disclaimer: All comments are personal opinion only and may not indicate a claim of actual fact. chiefeis and Logan5 2 Quote
cdesigns Posted October 27, 2016 Author Posted October 27, 2016 Thanks for the info, makes sense about interfering with repeaters in the area. Durake 1 Quote
ULTRA2 Posted February 21, 2019 Posted February 21, 2019 Ok so if this is the case my question is are simplex users responsible to check if anyone is using the same frequency on duplex mode? Several times i am chatting with my friends and i seem to hear someone else riding on my friends signal. I asked if someone want to use the repeater no answer and as soon we got back into our conversation it happends again. So i went to simplex mode and sure thing i heard several station chatting on simplex pretty close to me and I told them that there's repeater traffic on the frequency and they were gentlemanly enough to change channels but normally are the simplex users responsiblity to check before they key up? Frequency is 462.700 (No tones due to privicy and owner requset) Quote
PastorGary Posted February 21, 2019 Posted February 21, 2019 Some information in this old thread was based upon the old (pre April 2017) regulations. The new regulation wording allows simplex fixed location to fixed location operation on the 467 mains as long as the RF out of the radio antenna connector does not exceed 15 watts. The new Part 95 Fixed station regulations do not limit the type of antenna, antenna gain or ERP while using the 467 mains.Refer to 95.1763 ( c) for the new operational content, which does not restrict fixed to fixed operations on the 467 mains - as well as 95.1767 (a ) (2) for power requirements of fixed stations. Note FCC Part 95 Definition: "Fixed station. A station at a fixed location that directly communicates with other fixed stations only." *** Fixed stations operating on the 467 mains are not limited to repeater access only under the new rules *** Quote
Elkhunter521 Posted February 22, 2019 Posted February 22, 2019 I was confused about "fixed" stations before this. Also about the usage of the 467mHz repeater frequencies. Wow, its amazing how just a little bit more knowledge can create a total absence of comprehension. Quote
Ian Posted March 10, 2019 Posted March 10, 2019 467.5750 467.6000 467.6250 467.6500 467.6750 467.7000 467.7250 So we are licensed to transmit on this frequencies and receive 5mhz lower on a repeater setup right? But can we TX/RX on those 467mhz frequencies Simplex mode TX and RX on 467mhz? I'm looking for just a little more privacy when traveling and stay away from bubble pack GMRS people It should be legal right? If you want privacy, I'd recommend the Motorola 900 MHz FHSS gear. It's obscure enough that nobody really uses it, proprietary enough that there's not any scanning hardware for it (to my knowledge), and if you feel clever you can get the old gear and run a mag-mount antenna. What do you need privacy for, anyway? Just don't want incessant, irrelevant chatter, or something? Quote
