WSDE521 Posted July 10, 2024 Report Posted July 10, 2024 I am extremely new to this and want to start using my radios ! I have stage four brain cancer and sometimes I don’t comprehend everything right away and I forget easily! Just my short term memory is affected , please give me some pointers. I live in Conway SC near Myrtle Beach and was wondering if there is a group in my area that can help me understand how to enjoy this as a hobby, with my illness, I am kinda restricted to what I can do. Other than sleep and watch TV . Any help would be greatly appreciated!!! Quote
TrikeRadio Posted July 10, 2024 Report Posted July 10, 2024 I don't know anything about them but I googled this GMRS club in your state... https://upstatescgmrs.com/announcements WRXB215 and WRPG745 2 Quote
WRPG745 Posted July 10, 2024 Report Posted July 10, 2024 Hi WSDE521, let us know what radio you have so we can give you specific tips. I'm sure you'll be able to get up to speed quickly. I don't live near you, but I did see this ham club that might be able to help you for local info: https://w4gs.org/ Use the map feature (on mygmrs.com) to find a local repeater like this one: https://mygmrs.com/repeater/1675 If you live in the green circle, click the blue button on that page to request access. You can listen in to see if there is activity by tuning into 462.550mhz (channel 15), but you will only be able to listen. to talk, you'll need to program the repeater channel using tones. once you tell us your radio, someone will be able to tell you how to program the radio for that repeater. take your time and read the manual. -jc TrikeRadio 1 Quote
WSDE521 Posted July 10, 2024 Author Report Posted July 10, 2024 11 minutes ago, WRPG745 said: Hi WSDE521, let us know what radio you have so we can give you specific tips. I'm sure you'll be able to get up to speed quickly. I don't live near you, but I did see this ham club that might be able to help you for local info: https://w4gs.org/ Use the map feature (on mygmrs.com) to find a local repeater like this one: https://mygmrs.com/repeater/1675 If you live in the green circle, click the blue button on that page to request access. You can listen in to see if there is activity by tuning into 462.550mhz (channel 15), but you will only be able to listen. to talk, you'll need to program the repeater channel using tones. once you tell us your radio, someone will be able to tell you how to program the radio for that repeater. take your time and read the manual. -jc Thank you , this is what I have,, Quote
WSDE521 Posted July 10, 2024 Author Report Posted July 10, 2024 Thank you, I live inside the green circle, I am reading the manual again! I appreciate your input and will keep trying! I have read that this type of radio is much better than CB radios, I have used many GRMS radios in my line of work, but never had to really do anything but talk on them . Quote
WRPG745 Posted July 10, 2024 Report Posted July 10, 2024 cool, so I don't know this particular radio, but see the button VFO/MR? That selects between channels and frequency (MR is probably "Memory Recall" and VFO is "Variable Frequency Oscillator", or what humans call "tuning") it looks like you have some channels programmed already. use the arrow up and down to scroll through them. see if channel 015 shows the frequency 462.550 you can also select VFO and enter the numbers 462550 (should tune to that frequency) good luck! WSDE521 1 Quote
WSDE521 Posted July 10, 2024 Author Report Posted July 10, 2024 22 minutes ago, TrikeRadio said: I don't know anything about them but I googled this GMRS club in your state... https://upstatescgmrs.com/announcements Thank you, I do live in the green circle, I am still reading the manual, it can’t be as hard to use as it appears in the instructions, I will figure it out with a little help on here ! TrikeRadio 1 Quote
WSDE521 Posted July 10, 2024 Author Report Posted July 10, 2024 2 minutes ago, WRPG745 said: cool, so I don't know this particular radio, but see the button VFO/MR? That selects between channels and frequency (MR is probably "Memory Recall" and VFO is "Variable Frequency Oscillator", or what humans call "tuning") it looks like you have some channels programmed already. use the arrow up and down to scroll through them. see if channel 015 shows the frequency 462.550 you can also select VFO and enter the numbers 462550 (should tune to that frequency) good luck! Thank you very much Quote
WSDE521 Posted July 10, 2024 Author Report Posted July 10, 2024 4 minutes ago, WRPG745 said: cool, so I don't know this particular radio, but see the button VFO/MR? That selects between channels and frequency (MR is probably "Memory Recall" and VFO is "Variable Frequency Oscillator", or what humans call "tuning") it looks like you have some channels programmed already. use the arrow up and down to scroll through them. see if channel 015 shows the frequency 462.550 you can also select VFO and enter the numbers 462550 (should tune to that frequency) good luck! Quote
Hoppyjr Posted July 10, 2024 Report Posted July 10, 2024 Hey new guy - welcome to GMRS and the forum. Stay in the fight and try to keep positive. Quote
