SteveShannon Posted July 24 Report Share Posted July 24 6 minutes ago, pl4tinum said: ve experienced duplex grunge testing an RT97S with a Nagoya UT-72 antenna which is about 15 feet of PL-259. I believe that coax is a copper clad aluminum center and copper clad aluminum braiding. After releasing PTT there would be a low pitch screech which would sometimes continue activating the repeater for a few seconds. PL-259 is simply the connector, also referred to historically as the UHF connector. The actual cable type should be marked on the jacket of the cable. WRXB215 and WRUU653 1 1 Quote Link to comment Share on other sites More sharing options...
pl4tinum Posted July 25 Report Share Posted July 25 On 7/24/2024 at 9:46 AM, SteveShannon said: PL-259 is simply the connector, also referred to historically as the UHF connector. The actual cable type should be marked on the jacket of the cable. Well that's embarrassing, I must have been typing too fast and not paying attention. The coax on the UT-72 is RG-58A/U which I believe is tinned copper for the braid. Quote Link to comment Share on other sites More sharing options...
SteveShannon Posted July 25 Report Share Posted July 25 1 minute ago, pl4tinum said: Well that's embarrassing, I must have been typing too fast and not paying attention. The coax on the UT-72 is RG-58A/U which I believe is tinned copper for the braid. I’ve certainly typed similar brain farts. Don’t be embarrassed. But one thing to be aware of is the power attenuation that happens at GMRS frequencies in RG-58A/U. It’s not insignificant as something I wrote recently was corrected. Quote Link to comment Share on other sites More sharing options...
WSDU214 Posted 18 hours ago Author Report Share Posted 18 hours ago On 7/20/2024 at 6:14 PM, SteveShannon said: The radio plus repeater setup in the pictures is not GMRS and will not support GMRS radios. Folks, I finally creaed a simple base station with my GMRS radios, thank you for all your advices. After reasearching further, I noticed that this Retevis RB91 that comes with its own 2 way radio enhances the distance for the hand helds without the need of a GMRS base station more on a private level. Is this repeater legal here in the US? Does FCC allow the use of this repeater with our GMRS licenses? Quote Link to comment Share on other sites More sharing options...
Socalgmrs Posted 17 hours ago Report Share Posted 17 hours ago 45 minutes ago, WSDU214 said: Folks, I finally creaed a simple base station with my GMRS radios, thank you for all your advices. After reasearching further, I noticed that this Retevis RB91 that comes with its own 2 way radio enhances the distance for the hand helds without the need of a GMRS base station more on a private level. Is this repeater legal here in the US? Does FCC allow the use of this repeater with our GMRS licenses? No it does not. Aaand just so you know and understand nothing is private in gmrs everyone can hear everything TrikeRadio 1 Quote Link to comment Share on other sites More sharing options...
WSDU214 Posted 17 hours ago Author Report Share Posted 17 hours ago @Socalgmrs thank you for your quick response. So this UHF repeater is not legal to use in the US per FCC correct? Quote Link to comment Share on other sites More sharing options...
WRXB215 Posted 16 hours ago Report Share Posted 16 hours ago @WSDU214 You aren't allowed to use digital on GMRS except for very short bursts i.e. location or short text message. Quote Link to comment Share on other sites More sharing options...
