WRVG829 Posted August 5, 2024 Report Posted August 5, 2024 I purchased a Retevis RA-86 recently and have come to the conclusion that the receive side of the radio is defective. Strong signals that will come through just fine on a handheld are broken up and sometimes completely wiped out by static on the RA-86, both in simplex and repeater mode. I've upgraded the antenna that came with the unit with a Nagoya UT-72G with no change in reception. I've also added a ferrite choke to the power cable; no observable change. I've run a QYT KT-8900 in this vehicle for years without reception issues with a different (2M/70CM combo) antenna; I don't think the source of the noise is the vehicle's electrical system. So here's what I want to know: is the RA-86 just an inherently poor quality radio? Is the BTECH GMRS-20V2 any better with regard to RX/TX? Because of the layout of the dash in my truck and my desire to keep the radio movable from one vehicle to another, I'm favoring the 'one hander' style radios with all of the controls and channel display in the microphone. I need to be able to use this on both simplex and repeaters. Is the Midland MXT-275 of better quality? I've heard such negative things about Midland radios from the Queen, I'm not sure I want to even try one. Anyone got a clear view on the relative merits of these? Quote
jwilkers Posted August 5, 2024 Report Posted August 5, 2024 I have the BTECH. Nice radio. I haven't experienced any rx/TX issues.Sent from my SM-S911U1 using Tapatalk WRVG829 1 Quote
Guest Posted August 5, 2024 Report Posted August 5, 2024 I won’t touch a retivis radio. BUT. Have you checked swr? Antenna? Coax? Mounting? I own one btech and like it only slightly more than retivis. In all our trucks and side by sides we run the tyt th8600. Zero issues with them in the rain snow heat cold dust ect. Quote
WRVG829 Posted August 5, 2024 Author Report Posted August 5, 2024 1 hour ago, WRXP381 said: I won’t touch a retivis radio. BUT. Have you checked swr? Antenna? Coax? Mounting? I own one btech and like it only slightly more than retivis. In all our trucks and side by sides we run the tyt th8600. Zero issues with them in the rain snow heat cold dust ect. I could just reprogram the ham radio I already have (QYT KT-8900) for GMRS frequencies and call it a day. I would prefer an integrated unit that has the controls and display in the microphone as I have really no need for amateur radio in the vehicle and I'm trying to cut down on my radio's footprint in the interior. If all of the microphone-integrated sets are junk then I'll reconsider. The form factor of the RA-86 is perfect, the sound reports I've gotten are good, it's just that receive is terrible. If there's some filtering I can do on the antenna side maybe it's worth it. Quote
WRYZ926 Posted August 5, 2024 Report Posted August 5, 2024 The Wouxun KG-XS20 G is an excellent Type 95 certified 20 watt radio. Yes it costs more than a Baofeng or Retevis radio. But the price is worth it. The Wouxun is IP65 rated. I use one in my SxS. Now if you don't care about having a Part 95 certified radio, then I will also recommend the TYT TH-8600. The TH-8600 is also IP65 rated. Now I do have to use an external speaker with the KG-XS20G and TH-8600 on the SxS since it is pretty loud. The 20 watt Midland SPK100 is an excellent speaker and I can hear the radio while driving around at 30+ mph on the SxS. Quote
amaff Posted August 6, 2024 Report Posted August 6, 2024 The BTECH GMRS-20V2 is the worst radio I've ever used. Awful interface, and then it stopped receiving after about a week. Back to the rainforest it went. SteveShannon 1 Quote
WSCY649 Posted August 6, 2024 Report Posted August 6, 2024 I have both and no problems with either of them. The BTech has the better display since it shows no just channel numbers but individual names for channels Programms beyond what is stock. The RA86 is just very basic. Quote
Frdbronco8 Posted January 8 Report Posted January 8 On 8/5/2024 at 11:39 AM, WRVG829 said: I purchased a Retevis RA-86 recently and have come to the conclusion that the receive side of the radio is defective. Strong signals that will come through just fine on a handheld are broken up and sometimes completely wiped out by static on the RA-86, both in simplex and repeater mode. I've upgraded the antenna that came with the unit with a Nagoya UT-72G with no change in reception. I've also added a ferrite choke to the power cable; no observable change. I've run a QYT KT-8900 in this vehicle for years without reception issues with a different (2M/70CM combo) antenna; I don't think the source of the noise is the vehicle's electrical system. So here's what I want to know: is the RA-86 just an inherently poor quality radio? Is the BTECH GMRS-20V2 any better with regard to RX/TX? Because of the layout of the dash in my truck and my desire to keep the radio movable from one vehicle to another, I'm favoring the 'one hander' style radios with all of the controls and channel display in the microphone. I need to be able to use this on both simplex and repeaters. Is the Midland MXT-275 of better quality? I've heard such negative things about Midland radios from the Queen, I'm not sure I want to even try one. Anyone got a clear view on the relative merits of these? Curious what you ended up doing. I was just programing one for a friend and noticed the same thing. I did a radio check on a somewhat distant repeater and recieved a reply that I could hear on my nearby handheld. The reply said I sounded very clear on the ra86 but I couldn't hear the response on the ra86, only occasional static. Quote
WSGG576 Posted January 14 Report Posted January 14 I should receive the RA86 within days according to shipment tracking. I ordered it direct from Retevis; $89 with the programming cable and the 3db (dinky) antenna. I cannot yet comment on the radio's quality or function. I can however comment on Retevis customer service. They seem to take customer concern seriously (as far as I can tell) and have stated that the aforementioned reception issues have been addressed. We shall see. Otherwise, I've previously made a couple HT purchases directly from Retevis and so far so good. I figured $89 bucks is worth a shot for camping/kayaking/fishing coms. No cell service where we spend a lot of the summer adventures. If anyone is interested I'll update, if not, Best to ya! Quote
WRVG829 Posted February 23 Author Report Posted February 23 On 1/7/2025 at 10:45 PM, Frdbronco8 said: Curious what you ended up doing. I was just programing one for a friend and noticed the same thing. I did a radio check on a somewhat distant repeater and recieved a reply that I could hear on my nearby handheld. The reply said I sounded very clear on the ra86 but I couldn't hear the response on the ra86, only occasional static. I went with the BTech GMRS 20-V2. It works fine. People with open air vehicles like Jeeps and side by sides don't like 'em because the audio isn't strong enough to overcome all the noise. Inside a normal passenger vehicle like my RAM, it's no problem. Yes, adjusting the volume is funky. I don't care. I adjusted it once and it's fine. I was not disappointed. Quote
WRYZ926 Posted February 23 Report Posted February 23 The 20 watt Midland SPK100 is a good choice for open air vehicles like Jeep Wranglers and side by sides. I installed the SPK100 in my Honda Pioneer 500 and can hear just fine while traveling at 35 MPH down gravel roads. Quote
