WRYG716 Posted August 11 Author Report Posted August 11 9 minutes ago, OffRoaderX said: Maybe you should take it back to the guy you got it from and tell him you want one that works? Yeah that’s probably the next step. I’ve already contacted him about it and he said it worked when he pulled it so we will see gortex2 1 Quote
MarkInTampa Posted August 11 Report Posted August 11 One more thing I can think of to at least try... Test to make sure the repeater is actually receiving and saving the data from the CPS. Since the repeater doesn't show frequency, just the channel number, the simplest way I can think to do that is to double click on channel 2 and it will turn grey (disabled) and save the config to the repeater. Then change the channel on the repeater and it should skip 2, if it doesn't it's probably not saving correctly to the repeater. Other than that - no idea Quote
WRYG716 Posted August 11 Author Report Posted August 11 Yes it’s working I did 16 channels then erased all and went to 1 channel there was only 1 on the repeater Quote
WRYG716 Posted August 14 Author Report Posted August 14 So sent the repeater back to seller he’s gonna run some test and see if it’s fixable. If not we are trading for a icom 4000 so we will see. Thanks everybody for the help! It’s very much appreciated. WRXB215, OffRoaderX and SteveShannon 3 Quote
OffRoaderX Posted August 14 Report Posted August 14 Please update us and let us know what he finds. WRYG716 and SteveShannon 2 Quote
