programming a base station TK-880
WSDX985
Good Evening,
I am trying to program my base station to hit a repeater in my area. attached is photos of the channel information and the optional features. i can hear all day but I cannot key up and talk. I can on simplex to my private channel I use for family but not any repeaters. I am running my base station with a Kenwood ps-430.
7 answers to this question
its all good. i thank you for your help. i can hit the repeater with my handheld system. if the power converter draws down on power and the fan sound like to looses momentum would that cause a problem. i am pulling at strings at this point to get it to work. if i cant get it i may just get a new base station.
You need a 30amp power supply at 13.8-14.1 volts. What co-ax are you running? How many feet? To what antenna? Do you have line of sight to the repeater? How far away is it?
So I have a small antenna that is for a mobile vehicle antenna. I am not getting out to any repeater. I believe it is my power supply is not putting out enough power while transmitting I do believe my power supply is on its last leg. Looking at replacing. I’m approximately 40 miles from the repeater. I’m trying to hit however I can hit it on my handheld just not my homebase station and I do believe that is because of the power supply. I will be upgrading soon.
