I have a Baofeng UV-5G Plus. I set it to channel 15 / 462.5500 and tested it in narrowband mode, as well as in wideband mode. I've been able to observe bandwidth using a TinySA with other radios (Retevis RA87, Baofeng UV-5G --not "plus", and MXT275). But with this radio I don't see a difference in transmissions between a narrowband and wideband setting.
dosw
The test setup:
Baofeng UV-5G Plus -> 10w 40dB attenuator -> 10w 20dB attenuator -> TinySA
TinySA is set to center frequency of 462.5500, span of 12kHz, -61.5dB attenuation offset*.
Here are a couple pictures of the TinySA:
Narrowband setting for the UV-5G Plus:
And by comparison, here is wideband:
See the difference? I don't.
* (At 12kHz it still shows a broader band, because there's room on the screen. At 25kHz span, it's still identical).
* (-61.5dB, because my NanoVNA says that my total attenuation is -61.5dB, not "40+20=60".)
Is the radio just not switching to narrowband?
2 answers to this question
