Does anyone have any suggestions for cb radio repair / diagnostics in Central New York. I'm having a high SWR reading.  I checked and made sure the ground was proper and it has a brand new coaxe cable.  Its in a 1998 Jeep Cherokee with antenna mounted on rear tire carrier.
Where are you testing the SWR? Test it where the coax goes into the antenna to be certain your coax is good. You'll need to use a dummy load in place of the antenna. Also be certain you have the correct SWR/Power meter as the GMRS ones are not designed to work on CB frequencies.
BobsCB.com   I had a galaxy repaired a few back..  (couple years)  Same problem finals out..  I remember i sent the radio UPS two day, i had it back the same week..  I think Bobs is in PA..
The last place in Syracuse closed up about 10 years ago. There was a mobile guy at the Truck Stop in Parish a few years back but not sure he is still around. Maybe check the Flying J on 7th North ?
The tire carrier is junk for a CB antenna location so I'm not surprised. Youd be better off on the roof.
