Midland GXT67 Pro
I’ve purchased 3 of these units to communicate with my family. Outdoors I’ve had no issues reaching a repeater 7.5 miles from my home.  Indoors it’s sketchy at best with static reception.  Any suggestions as to how to increase reception indoors with the handhelds?
10 answers to this question
A better antenna would help.  7.5miles is very very close.  We reach repeaters over 40miles away inside our home with a 5w ht and a 771 antenna.  But maybe it’s just the cheapy radios. For the price of one midland I get 8-10 hand helds.   Heck I can even buy 2 professional motorolas.
Older homes with foil backed insulation, aluminum or steel siding and metal roofs can cause issues. All metal buildings are even worse. My brother built a metal building as his home and it acts like a giant faraday cage. He can't use his HT's inside the house even with the repeater being 5 miles or less from him. 70cm and GMRS are worse than 2m .
  On 10/18/2024 at 7:44 PM, WRYZ926 said:
Older homes with foil backed insulation, aluminum or steel siding and metal roofs can cause issues. All metal buildings are even worse. My brother built a metal building as his home and it acts lie a giant faraday cage. He can't use his HT's inside the house even with the repeater being 5 miles or less from him. 70cm and GMRS are worse than 2m .
Expand
Yeah, plaster construction in and out.  I was hoping I could add some sort of indoor boost to an outside antenna to help the handhelds when indoors.  They are solid outside, but limited as you move to the interior.
  On 10/18/2024 at 8:09 PM, amaff said:
not all homes are built the same.
Expand
This is very true. And the band/frequencies used will make a difference too. I can reach the local 2m repeater that is 21.5 miles away with a HT inside my house. Some brands of radios do better than others. My Icom and Wouxun HT's work the best. But I can totally forget about trying to get into the 70cm and GMRS repeaters from inside the house with a HT. This shows the difference between VHF and UHF. All three repeaters are on the same tower.
I can't even get into the 70cm repeater with a HT outside in my yard and getting into the GMRS repeater is very hit or miss.
Expand
Ouch. The old lathe and plaster walls are going to give you all kinds of grief since most have chicken wire inside the plaster. Your best bet is to pick a spot inside to keep a HT at and run it to an outside antenna.
Expand
Yeah, I guess I’m going to have to just establish a base station inside and run it to an outside antenna for indoors.  The GXT67’s are sweet outside, but you can’t remove the antennas.
There are plenty of good 20-25 watt mobile radios that will work just fine without breaking the bank. A good antenna and quality LMR400 or equivalent coax is important. I have had good luck with the Jet Flex400 coax from R & L Electronics and the DX Engineering 400Max coax.
Because Midland radios do not have a removable antenna I must use other radios. In my home office I use two Tidradio H3 on GMRS, connected to a GMRS mag mount antenna on a pizza pan. The Tidradio H8 is Ham, connect to a mag mount antenna on a cast iron pan. Although we are surrounded by hills, they both hit connect to repeaters about thirty-five miles away. In our area simplex is often a challenge, 1-3 miles at best.
The repeater we access has about 85-mile diameter coverage, physical repeater is about 35 miles from my location. Also, I have two very old rarely used Midland LXT310 HT, they work as new, not repeater capable. My two other radios, again H3 and H9 are in my vehicle, used as mobile radios. H3 for GMRS is connected to Midland's MXTA12 mag mount antenna with Midland's ghost antenna, MXTA25, then as needed we use MXTA26; their ghost antenna is a very good antenna.
The aforementioned is to emphasize, it is all about the antenna and repeater coverage. Depending on your location simplex connections can be quite challenging. Midland, make your radios with removable antenna.
