Tidradio h8
Hello
Just purchased  the h 8 and tested the power on several  channels and only getting  an average  of 2.5 watts not ten as advertised.  I did reset to unlock and not any better channel 5 on gmrs was 1.78 watts. I'm  guessing  I have a defective  radio or is there a fix for it?
11 answers to this question
  On 10/27/2024 at 5:39 PM, WSDM599 said:
Hello
Expand
How are you testing the power output?
What is the output power when the radio is set to low power?  There have been reports of Chirp swapping the high and low power settings such that higher output power is observed when the radio is set to low power. I have not seen that myself.
I noticed my tdh8 not being as good as my other radios in fars..
I dont have a power meter but i ran the power tuner program and although it would not allow me to read, i heard hitting write did not require the password. Nothing really made me thing that it took, however it can hit repeaters that it couldn't before. Look into running that application.
Expand
no difference at all , but thanks for the try
Expand
I'm not familiar with that program. where can i find it. thank you
  On 11/21/2024 at 6:02 PM, WSDD519 said:
Keep in mind the H8 is 10 watts ONLY on VHF.  For UHF, it's 5 watts.   I've confirmed this with three different radios.
Expand
After using the power tuner, I get at least 8 watts everywhere, and over 10 watts in some frequencies, even uhf/gmrs frequencies. It does tend to shoot less than 10 watts on the repeater inputs though, which is disappointing.
One point that is cool, is the low power mode can put out very low power, if you had a use case for that.
