Radioditty Handheld won’t communicate with RD mobile on repeater channel
Good day all and thank you for allowing me to join.
Just got my RD GM30. Been a GMRS user for about 5 years I have a base station (RD DB20G) that regularly connects to a repeater (40ft directional).
I have configured the GM30 to the same repeater channel and the corresponding tx and rx CTCSS.
When I transmit I can see the base station “receiving” but I do not hear myself. I have a TDH3 set to the same and it communicates with the base/mobile with no problems.
Any ideas from seasoned GM30 users? Thank you in advance!
Edit: the base receives all channels 1-22 5 by 5.
2 answers to this question
So your base station hits the repeater but your ht does not?
how far from the repeater are you. Remember you’ve got a 20w base with an antenna up high. Then you have an ht with a small antenna down low.  Sounds like it’s open repeater squelch but not getting the voice to the repeater well enough for it to transmit.  An ht will have a mile to 60miles depending on line of sight.
