RollTide Posted Monday at 04:52 AM Report Share Posted Monday at 04:52 AM I have a TIDRADIO TH-3 I tried to download the new saftware and not it want work anymore what do I do get it to come back on and working again Quote Link to comment Share on other sites More sharing options...
0 BoxCar Posted Monday at 12:55 PM Report Share Posted Monday at 12:55 PM Why did you attempt a firmware update? Was there a problem with your radio the update was supposed to fix? The old saw, "If it isn't broken, why fix it" applies. This goes along with the caution that an incorrectly applied update will make your radio unusable. Quote Link to comment Share on other sites More sharing options...
0 Socalgmrs Posted Monday at 01:48 PM Report Share Posted Monday at 01:48 PM An issue with a h3? . I’ve never once wanted to or needed to update firmware. It’s just a radio. you may be able to re download the new firmware. Or try the old firmware. Or it might just be a brick. Quote Link to comment Share on other sites More sharing options...
0 SteveShannon Posted Monday at 01:53 PM Report Share Posted Monday at 01:53 PM 9 hours ago, RollTide said: I have a TIDRADIO TH-3 I tried to download the new saftware and not it want work anymore what do I do get it to come back on and working again support@tidradio.com Quote Link to comment Share on other sites More sharing options...
0 LeoG Posted Monday at 03:45 PM Report Share Posted Monday at 03:45 PM You should be able to do the firmware update again. Setup the firmware program by starting it and then load the proper BIN file into it. Connect the USB dongle to the computer and make sure the COM port is selected and accepted. Plug the USB dongle into the radio which should be off. Then press the PTT button and turn the radio on. The blue bar on the program should start moving up. I don't know if you can release the PTT button or not, I don't until the update is complete. When it does complete press the END button, turn off the radio, unplug the USB dongle and turn the radio back on. Hopefully it works. SteveShannon 1 Quote Link to comment Share on other sites More sharing options...
RollTide
Link to comment
4 answers to this question
