I just received two GM-15Pro's from Amazon and when I got them setup in Radioddity they seem to have an incorrect TX frequency for all the DIY channels. Has anyone seen this? Is there a way to factory reset the radio, or do I need to send it back?
I’d say fix it.   That’s why I clear out every radio I buy and start over.  Doesn’t really matter how or why it’s this way. Just fix it and move on.
Yes, i've seen this multiple times with a couple of different manufacturers.  You can try a factory-reset, but in most cases that just puts it back the same way because its burned-in to the chips wrong.
Manually changing the frequencies is probably going to be your ultimate fix.
You shouldn't have to do this but you can fix this as follows:
1) Click on the >> to the right
2) Change the frequency in the RX and then change it right back to what it was.
3) Click on the X to close the window.
The TX will not be what it is supposed to be.
Factory Reset didn't fix it :(
Factory reset didn't work. Unfortunately radioddity GM-30 doesn't let me edit the field
Didn't work :(
Maybe i'm missing it in your screenshots - is the offset correctly set at +5Mhz?  If the offset is correct but its still calculating it wrong/you can't manually fix it, then box that junk up and send it back to Amazon and get your money back - you've already wasted more time on it than its worth.
the +5 offset is correct (462/467) but the "." frequency is not correct. No way to manually change it, at least with GM-30 Radioddity.
I have definitely wasted too much time on a $25 radio. I am going to order some UV-5G's and hopefully have better luck.
THx
I had all the same problems with this radio plus you cannot add simplex channels. Sent them back, gave Baofeng a bunch of feedback per their request, bought some TID H-3's and never looked back.
