WRDU469 Posted November 8, 2024 Report Posted November 8, 2024 Does someone know what the GMRS transmit limitations are for this radio? I have the latest firmware and set to GMRS mode. I added my programming for several repeaters, etc. I noticed that I cannot transmit (only receive) on channels 55 and up. Ch 1-54 I can transmit on simplex or repeaters. Others see this issue or is this known? I could not find anything in the manual about this unless I totally missed it. Quote
amaff Posted November 8, 2024 Report Posted November 8, 2024 It's known. And dumb, but it's how the radio is. You're only allowed that handful of 'DIY' GMRS channels. Quote
WRDU469 Posted November 8, 2024 Author Report Posted November 8, 2024 5 minutes ago, amaff said: It's known. And dumb, but it's how the radio is. You're only allowed that handful of 'DIY' GMRS channels. Yeah that is dumb. I wish I knew this earlier. Thx Raybestos 1 Quote
Guest Posted November 8, 2024 Report Posted November 8, 2024 5 minutes ago, WRDU469 said: Yeah that is dumb. I wish I knew this earlier. Thx Loads of posts about all the issues with this radio. It’s not as good as some people would have people believe. Sorry it didn’t work out Quote
OffRoaderX Posted November 8, 2024 Report Posted November 8, 2024 4 minutes ago, Socalgmrs said: ....It’s not as good as some people would have people believe. You forgot to say that everyone you know that bought one has returned them or thrown them into the trash.. amaff, RIPPER238, WRYZ926 and 2 others 1 4 Quote
WRDU469 Posted November 8, 2024 Author Report Posted November 8, 2024 Well, I did see a lot of good reviews on YouTube. No where have I seen this limitation mentioned. I wish TIDRadio was more forthcoming of this. TrikeRadio 1 Quote
RIPPER238 Posted November 8, 2024 Report Posted November 8, 2024 1 hour ago, WRDU469 said: Does someone know what the GMRS transmit limitations are for this radio? I have the latest firmware and set to GMRS mode. I added my programming for several repeaters, etc. I noticed that I cannot transmit (only receive) on channels 55 and up. Ch 1-54 I can transmit on simplex or repeaters. Others see this issue or is this known? I could not find anything in the manual about this unless I totally missed it. It will transmit and receive on all GMRS frequencies 1-22 plus others you program. Not sure what 55 and up means. Love my H3, definitely the best radio by far in its price point. GrouserPad and RayDiddio 2 Quote
WRDU469 Posted November 8, 2024 Author Report Posted November 8, 2024 5 minutes ago, RIPPER238 said: It will transmit and receive on all GMRS frequencies 1-22 plus others you program. Not sure what 55 and up means. Love my H3, definitely the best radio by far in its price point. It means any GMRS frequency programmed in to Channels 55 or higher will not transmit. Sounds like the DIY channels for GMRS are limited. Quote
RIPPER238 Posted November 8, 2024 Report Posted November 8, 2024 Just now, WRDU469 said: It means any GMRS frequency programmed in to Channels 55 or higher will not transmit. Sounds like the DIY channels for GMRS are limited. O, damn that's a lot of GMRS repetitive frequencies to program in there since there are only 22. I don't have that issue, but i also haven't added GMRS passed 36. But i do have many other frequencies programmed and have no issues. TrikeRadio, RayDiddio and WSDD439 3 Quote
TrikeRadio Posted November 8, 2024 Report Posted November 8, 2024 9 minutes ago, RIPPER238 said: ...Not sure what 55 and up means. It means the channel slots the radios has... (there 199 of them) will not transmit on channel above 54. You can only put in listen only there. So any custom legitimate GMRS frequencies can only be put in below 55. I found this out when I was starting to add a lot more repeaters into my radio. Only way around this... is to unlock it in NORMAL mode and be very careful how you program so you don't set something up that has you transmitting on non permitted frequencies. RayDiddio, RIPPER238 and WRHS218 3 Quote
WRDU469 Posted November 8, 2024 Author Report Posted November 8, 2024 3 minutes ago, TrikeRadio said: It means the channel slots the radios has... (there 199 of them) will not transmit on channel above 54. You can only put in listen only there. So any custom legitimate GMRS frequencies can only be put in below 55. I found this out when I was starting to add a lot more repeaters into my radio. Only way around this... is to unlock it in NORMAL mode and be very careful how you program so you don't set something up that has you transmitting on non permitted frequencies. That was going to be my next question/test of the radio. Will the other channels transmit on GMRS frequencies if the radio is in normal mode. You have done this and it works? Quote
RIPPER238 Posted November 8, 2024 Report Posted November 8, 2024 1 minute ago, TrikeRadio said: It means the channel slots the radios has... (there 199 of them) will not transmit on channel above 54. You can only put in listen only there. So any custom legitimate GMRS frequencies can only be put in below 55. I found this out when I was starting to add a lot more repeaters into my radio. Only way around this... is to unlock it in NORMAL mode and be very careful how you program so you don't set something up that has you transmitting on non permitted frequencies. I was going to say. lol 54 is a ton, but yeah i have mine in NORMAL mod so thats why its not been an issue. amaff and TrikeRadio 2 Quote
RIPPER238 Posted November 8, 2024 Report Posted November 8, 2024 1 minute ago, WRDU469 said: That was going to be my next question/test of the radio. Will the other channels transmit on GMRS frequencies if the radio is in normal mode. You have done this and it works? Do you have a Ham license? GMRS license? Quote
WRDU469 Posted November 8, 2024 Author Report Posted November 8, 2024 2 minutes ago, RIPPER238 said: Do you have a Ham license? GMRS license? Just GMRS. I wouldn't be programming any HAM frequencies. Quote
TrikeRadio Posted November 8, 2024 Report Posted November 8, 2024 7 minutes ago, WRDU469 said: That was going to be my next question/test of the radio. Will the other channels transmit on GMRS frequencies if the radio is in normal mode. You have done this and it works? I personally have not done it but heard from others that they have. NORMAL mode unlocks all the GMRS or HAM frequency "Safeguards" and rules... which of course makes it non compliant. You just have to be careful and know what you are doing when programming in normal so you don't end up transmitting unintentionally on frequencies that could actually get you in trouble. and know the Wide/Narrow and lower wattage levels allowed on GMRS "channels" as well to stay in compliance. Especially in the GMRS channels 8-14 where the power is half a watt and narrow... otherwise you can potentially send interference to local repeaters on those channels. RIPPER238 and RayDiddio 2 Quote
RayDiddio Posted November 9, 2024 Report Posted November 9, 2024 It's not a bad radio. You can unlock it or even put a VERY much more unlocked firmware on it (which I have) and it does what you mostly expect. For the price and features, it's a great little radio. Definitely not the best of the best, just ask the Queen about that and you will get a good radio, but it can and will get you started with a small and very lightweight unit that can get you some fars... as they say. amaff 1 Quote
RIPPER238 Posted November 9, 2024 Report Posted November 9, 2024 15 hours ago, WRDU469 said: Just GMRS. I wouldn't be programming any HAM frequencies. Then put it in NORMAL mode and make sure you never transmit on frequencies you are not aloud to. It's really awesome in NORMAL mode but you will have to start from scratch and program everything manually. Quote
WRDU469 Posted November 9, 2024 Author Report Posted November 9, 2024 43 minutes ago, RIPPER238 said: Then put it in NORMAL mode and make sure you never transmit on frequencies you are not aloud to. It's really awesome in NORMAL mode but you will have to start from scratch and program everything manually. When I get time, I will give it a shot. I have all my programming saved, so it shouldn't be a problem to reload or import. Thanks for the information. amaff and TrikeRadio 2 Quote
LeoG Posted November 9, 2024 Report Posted November 9, 2024 I sent a letter to Tidradio. Lets see if they respond to it and what they say. Quote
RayDiddio Posted November 9, 2024 Report Posted November 9, 2024 7 hours ago, RIPPER238 said: Then put it in NORMAL mode and make sure you never transmit on frequencies you are not aloud to. It's really awesome in NORMAL mode but you will have to start from scratch and program everything manually. You can easily restore the programming. Backup the programming with CHIRP Flash radio to NORMAL Read the radio AGAIN (this is per CHIRP) so CHIRP has the layout of the memory Re-upload your saved config via CHIRP back to the radio These were the steps I followed and it worked flawlessly for me. I have done this going from GMRS to ham to NORMAL modes and back. It has worked each time. RIPPER238 1 Quote
LeoG Posted November 9, 2024 Report Posted November 9, 2024 If you have a 2nd radio just clone it and you can restore it quick and easy too. TrikeRadio and RIPPER238 2 Quote
WSDD439 Posted November 10, 2024 Report Posted November 10, 2024 On 11/8/2024 at 4:28 PM, WRDU469 said: Does someone know what the GMRS transmit limitations are for this radio? I have the latest firmware and set to GMRS mode. I added my programming for several repeaters, etc. I noticed that I cannot transmit (only receive) on channels 55 and up. Ch 1-54 I can transmit on simplex or repeaters. Others see this issue or is this known? I could not find anything in the manual about this unless I totally missed it. I have both the H-3 and H-8, and couldn’t be happier with them ! Fortunately, I live near a fantastic repeater, and I talk all over the place. They work so well, I don’t plan on having a GMRS base station. Quote
RIPPER238 Posted November 10, 2024 Report Posted November 10, 2024 18 hours ago, LeoG said: If you have a 2nd radio just clone it and you can restore it quick and easy too. I purchased a 3rd H3 specifically because of this feature. lol So darn easy! RayDiddio 1 Quote
LeoG Posted November 13, 2024 Report Posted November 13, 2024 On 11/9/2024 at 4:46 PM, LeoG said: I sent a letter to Tidradio. Lets see if they respond to it and what they say. Hi Luxi, I was trying to program CH55 on my TD-H3 and noticed that I can't set it to a transmit frequency. Anything above CH55 is receive only. Is this correct? Is this a known limitation or is this just the way it's designed? Or is this something that needs to be looked into by the tech people? I found this on a GMRS forum and tested it out and found it to be true. I'm running version GMRS_240702. Thanks. support From:support@tidradio.com Tue, Nov 12 at 8:48 PM Yes, this is the limitation of the machine Luxi support@tidradio.com Quote
WRDU469 Posted November 13, 2024 Author Report Posted November 13, 2024 16 hours ago, LeoG said: Hi Luxi, I was trying to program CH55 on my TD-H3 and noticed that I can't set it to a transmit frequency. Anything above CH55 is receive only. Is this correct? Is this a known limitation or is this just the way it's designed? Or is this something that needs to be looked into by the tech people? I found this on a GMRS forum and tested it out and found it to be true. I'm running version GMRS_240702. Thanks. support From:support@tidradio.com Tue, Nov 12 at 8:48 PM Yes, this is the limitation of the machine Luxi support@tidradio.com Thank you! They didn't even respond to my email. Interesting they call a radio and "machine". Quote
